Overheating Im so Frustrated!!!
Old Mar 15, 2005 | 12:55 PM
vinasity's Avatar
Default Overheating Im so Frustrated!!!
I dont know whats wrong with my car its ran fine for almost 2 years with the swap and now it is starting to overheat. The car gets hot when im at a stop and i have to put the heater on full blast and then it goes down. I changed the thermostat and filled the radiator with new fluid. can anyone help?
Old Mar 15, 2005 | 01:00 PM
95sihb's Avatar
Default Re: Overheating Im so Frustrated!!! (vinasity)
more then likely you have air in the cooling system, the air is making the cooling system to overheat do-to not circulating...there is f.a.q @ the top of the forum to help you bleed the air out for your engine
Old Mar 15, 2005 | 01:03 PM
Junk Ex's Avatar
What are the swap details? Do you have any other details? Its hard to trouble shoot on so little info. Theres only a few things it could be, headgasket, heater core, or maybe even the water pump is shot, or the rad itself.
HitEm'Up's Avatar
Could have air pocket or just start by flushing the system
Old Mar 15, 2005 | 01:05 PM
SpoOoLin EK's Avatar
Default Re: Overheating Im so Frustrated!!! (98JRSChatch)
maybe your radiator fan switch is dead, and its keeping your car cool while moving. happened to a friend of mine. they sell fan switches
Old Mar 15, 2005 | 01:08 PM
tianporn's Avatar
Default Re: Overheating Im so Frustrated!!! (ReD . EK)
How do you know if your waterpump is shot? Will it start leaking or are there any other symptoms?
Old Mar 15, 2005 | 01:28 PM
SOKDO's Avatar
i'll put my bet on the Fan Switch which is located on the housing that has the thermostat.
Old Mar 15, 2005 | 01:34 PM
vinasity's Avatar
Default Re: Overheating Im so Frustrated!!! (sokdo321)
sorry its a 96 hatch with 2000 gsr swap with bolt ons. and the fan turns on but it does not turn on often. iv noticed when it starts to overheat the idle starts to go a little eratic and high
Old Mar 15, 2005 | 02:23 PM
95sihb's Avatar
you got air.............
Old Mar 15, 2005 | 02:48 PM
vinasity's Avatar
ok so i bleed the the rad and the block and let it run for like 20 min with the heater on full blast with cap off. hopefully this will fix the problem,it seem fine now
Bill Leland
Jun 12, 2014 02:29 PM
CSFDfirefighter
Dec 11, 2012 05:32 PM
darkblackH2B
Dec 15, 2008 07:08 PM
oorob00
13
May 10, 2004 06:31 AM
airborne84000
16
Jan 29, 2003 05:42 PM
