Overheating Im so Frustrated!!!
I dont know whats wrong with my car its ran fine for almost 2 years with the swap and now it is starting to overheat. The car gets hot when im at a stop and i have to put the heater on full blast and then it goes down. I changed the thermostat and filled the radiator with new fluid. can anyone help?
Re: Overheating Im so Frustrated!!! (vinasity)
more then likely you have air in the cooling system, the air is making the cooling system to overheat do-to not circulating...there is f.a.q @ the top of the forum to help you bleed the air out for your engine
What are the swap details? Do you have any other details? Its hard to trouble shoot on so little info. Theres only a few things it could be, headgasket, heater core, or maybe even the water pump is shot, or the rad itself.
Re: Overheating Im so Frustrated!!! (98JRSChatch)
maybe your radiator fan switch is dead, and its keeping your car cool while moving. happened to a friend of mine. they sell fan switches
Re: Overheating Im so Frustrated!!! (sokdo321)
sorry its a 96 hatch with 2000 gsr swap with bolt ons. and the fan turns on but it does not turn on often. iv noticed when it starts to overheat the idle starts to go a little eratic and high
ok so i bleed the the rad and the block and let it run for like 20 min with the heater on full blast with cap off. hopefully this will fix the problem,it seem fine now
Bill Leland
06-12-2014 02:29 PM
CSFDfirefighter
12-11-2012 05:32 PM
