I just got my car back from the shop and the crank balancer fell off
Old Mar 15, 2005 | 12:25 PM
90Integra's Avatar
Default I just got my car back from the shop and the crank balancer fell off
So I got my car back from the shop for doing an engine swap and I was about 20 miles away from the shop when THUNK. I heard a loud noise from my engine bay and my friend behind me saw sparks under my car. I pulled over to the side of the road and tried to see what happened but I couldn't see **** because it was dark. The shop towed the car back to their shop and told me the alternator belt broke and the crank balancer fell off. So if the crank balancer falls off does that mean my engine is fucked up?
Thanks for the help,
Old Mar 15, 2005 | 05:41 PM
Dragline's Avatar
Default Re: I just got my car back from the shop and the crank balancer fell off (90Integra)
no,you just need a new crank pulley and keyway and some loctite.
Also a new shop to take your car
Old Mar 15, 2005 | 05:49 PM
PrettyLude's Avatar
guess they forgot o tighten the crank pulley
Old Mar 15, 2005 | 06:32 PM
86si's Avatar
that sucks. you should be ok just inspect the end of the crank
Old Mar 16, 2005 | 05:55 AM
sleeper96's Avatar
Default Re: I just got my car back from the shop and the crank balancer fell off (86si)
Yeah you should be ok,just check everything and make sure nothing else got damaged when the crank pulley fell off.
Old Mar 16, 2005 | 12:16 PM
90Integra's Avatar
Cool thanks for the help. Hopefully the shop does the right thing.
Old Mar 16, 2005 | 02:13 PM
Slow ass EF's Avatar
Default Re: (90Integra)
check and make sure the timing belt didnt skip any teeth
Old Mar 17, 2005 | 08:18 AM
jweller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si &raquo;</TD></TR><TR><TD CLASS="quote">that sucks. you should be ok just inspect the end of the crank</TD></TR></TABLE>
definately check the end of the crank for damage.
Old Mar 17, 2005 | 08:57 AM
spoonek9's Avatar
Default Re: I just got my car back from the shop and the crank balancer fell off (dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">no,you just need a new crank pulley and keyway and some loctite.
Also a new shop to take your car</TD></TR></TABLE>
What the hell is the loctite for??
Old Mar 17, 2005 | 09:34 AM
PrettyLude's Avatar
Default Re: I just got my car back from the shop and the crank balancer fell off (spoonek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonek9 &raquo;</TD></TR><TR><TD CLASS="quote">What the hell is the loctite for??</TD></TR></TABLE>
its the same thing as threadlocker
Old Mar 17, 2005 | 12:20 PM
sleeper96's Avatar
So to make sure the bolt doesn't back our again.You could call it a safty precaution.
Old Mar 17, 2005 | 01:04 PM
spoonek9's Avatar
Default Re: I just got my car back from the shop and the crank balancer fell off (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">its the same thing as threadlocker</TD></TR></TABLE>
I know what locktite is, but I don't understand why you would use it on the crank pulley bolt.
Old Mar 17, 2005 | 01:06 PM
spoonek9's Avatar
Default Re: I just got my car back from the shop and the crank balancer fell off (sleeper96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper96 &raquo;</TD></TR><TR><TD CLASS="quote">So to make sure the bolt doesn't back our again.You could call it a safty precaution. </TD></TR></TABLE>
If you torque everything correctly you don't need loctite.
Old Mar 17, 2005 | 01:09 PM
h22 civic's Avatar
If you torque everything correctly you don't need loctite. </TD></TR></TABLE>
so what is loctiote made for??
Old Mar 18, 2005 | 04:05 AM
JimBlake's Avatar
Default Re: I just got my car back from the shop and the crank balancer fell off (h22 civic)
If you torque the crank pulley bolt correctly you don't need loctite. There's other bolts that need loctite. The Helm book tells you which ones...
Old Mar 18, 2005 | 04:36 AM
spoonek9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">so what is loctiote made for?? </TD></TR></TABLE>
The Helms manual tells you to clean the crank and pulley. Then you are supposed to put oil on the threads of the bolt and between the washer and head of the bolt. You reinstall the crank pulley and bolt and torque it properly.
If you put oil on the threads how is loctite even going to work??
Old Mar 18, 2005 | 07:56 AM
90Integra's Avatar
Thanks for all the help guys!!!!!!
Old Mar 21, 2005 | 11:49 AM
h22 civic's Avatar
If you put oil on the threads how is loctite even going to work??</TD></TR></TABLE>
the reason you put oil on the bolt is so you dont bind up and get false torque numbers pretty much any lube will do and in that case loctite is a lube as long as the bolt aint dry
Old Mar 21, 2005 | 05:33 PM
PrettyLude's Avatar
your not supposed to use loctite on the crank period
devilpuppy
Aug 30, 2024 09:15 AM
bks84
Engine Machining & Assembly
Jun 29, 2015 01:51 PM
jsnock
Feb 21, 2007 09:45 AM
civic_tuned
Feb 20, 2007 05:38 AM
ludedude00
Sep 15, 2004 05:44 PM
