Are there B-16,s out there running a greddy 18G turbo ?
Old Mar 14, 2005 | 10:29 PM
Evo-man@20psi's Avatar
Default Are there B-16,s out there running a greddy 18G turbo ?
If so what kinda hp/tq numbers should I expect ? Is the kit reliable ? Will the blue box have me running rich ? And any other suggestions before the install
Old Mar 15, 2005 | 06:53 AM
fipracing_com's Avatar
Default Re: Are there B-16,s out there running a greddy 18G turbo ? (Blue00vtecsi)
I had the civic SI greddy kit with intercooler, I used Hondata instead of the bluebox, and 550cc injectors . I put down 244whp, would have made more but my exhaust was too small and the greddy DP really hurts the flow. Greddy kit is realiable and EASY to install. When you do get the it be sure to dump the CAT, and install a BOV on the charge pipe as the greddy kit doesnt come with one, oh yeh get the intercooler as well. Lastly go with a heat range or two colder on the spark plugs as well. And if you havent already done so upgrade your clutch, my stock clutch held 195whp and wouldnt hold any more than 7psi of boost.
00sicain
Mar 6, 2009 02:21 PM
BlueTeg01
Aug 6, 2004 07:00 PM
AbsoluteCvc
Feb 4, 2003 07:26 AM
SOHC_MShue
Jan 10, 2003 09:31 AM
