NEED HELP from the pros- momo horn wiring on EK
Old Mar 14, 2005 | 04:01 PM
MASTRCHANN's Avatar
Default NEED HELP from the pros- momo horn wiring on EK
I have a momo monte carlo with the momo hub and i just need to know WHICH WIRE to tap into on the plug that goes behind the steering module. I'm thinking it's the gray one, but i'm not sure.
i know, this has been done to death and i've been searching the many threads about this, but all i've come up with is for 5th Gen 92-95. Apparently, the spot on the plug which i need to solder/connect a wire is already being tied up by this gray wire. Thanks in advance.
Old Mar 14, 2005 | 05:27 PM
MASTRCHANN's Avatar
Default Re: NEED HELP from the pros- momo horn wiring on EK (MASTRCHANN)
TTT. someone has to know what i'm talking about.
Old Mar 14, 2005 | 06:07 PM
MASTRCHANN's Avatar
are there no EK's out there with horns that work?
Old Mar 15, 2005 | 08:43 AM
MASTRCHANN's Avatar
one more time
Old Mar 15, 2005 | 10:27 AM
MASTRCHANN's Avatar
someone has got to know.
Old Mar 15, 2005 | 10:31 AM
Marauder's Avatar
I saved this link....
http://importnut.net/civicsteeringswap.htm
Hope it helps you.
Old Mar 15, 2005 | 10:42 AM
Relic1's Avatar
are you using the cable reel?
on the wheel side of the cable reel the wire is gray, on the car side of the reel it is blue then connects to gray wire under the steering column. (three pin gray plug)
if you're not using the reel, just find the three pin plug under the column that the reel used to connect to, and connect to the gray wire. ground is signal to turn on the horn.
Old Mar 15, 2005 | 02:11 PM
MASTRCHANN's Avatar
Default Re: (Relic1)
awesomeness. thanks.
Old May 21, 2005 | 11:33 AM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">if you're not using the reel, just find the three pin plug under the column that the reel used to connect to, and connect to the gray wire. ground is signal to turn on the horn.</TD></TR></TABLE>
I think that I'm trying this method...just curious weather I'm doing this right? I still can't get the horn to honk using the gray wire in the picture below.
This was originally plugged into the srs reel thingy. Not sure why I'm not getting it to work.
So what do I ground too?
Thanks
Old May 21, 2005 | 11:53 AM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: (gabebauman)
I got an EK. Its the grey one
Old May 21, 2005 | 11:58 AM
gabebauman's Avatar
Default Re: (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">I got an EK. Its the grey one </TD></TR></TABLE>
But when I stick the red wire (attached to the metal strip) to the grey horn wire in the clip and touch the brass piece to the back of the hub and press the horn button...nothing happens.
Do I need to ground something? What am I missing?
Modified by gabebauman at 3:09 PM 5/21/2005
Old May 21, 2005 | 12:05 PM
rukawa1one's Avatar
how many connection tabs on the back of the horn button?
Old May 21, 2005 | 12:13 PM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">how many connection tabs on the back of the horn button?</TD></TR></TABLE>
Two...one goes to the front of the hub and the ground one that is connected to the hub frame.
Modified by gabebauman at 3:27 PM 5/21/2005
Old May 21, 2005 | 12:26 PM
rukawa1one's Avatar
hmmm. ok it seems that the black one on the power, and the yellow one is the ground. I assume u have it hooked up correctly. Get a wire tester and stick it into the socket where the grey wire is. See if u are getting any power. If the horn indeed works, then it should go off as soon as u stick the wire tester in there. Test the other wires too, in case I may be wrong about the grey one. If all that doesnt work then check the horn fuse in the engine bay fuse box
Old May 21, 2005 | 12:28 PM
gabebauman's Avatar
VICTORY It was the red one. Thanks for the help rukawa1one
Old May 21, 2005 | 12:31 PM
rukawa1one's Avatar
EDIT: U got it? Good, cuz i didnt really feel like taking apart my car... LOL
Oh wait a minute... Your car is an EK right? That picture above is the harness u are trying to tap right? The one I used is lower, and the plastic harness is grey. Let me try to get a pic
MADEinJAPAN
Jun 30, 2003 09:08 PM
Tommy_Gunns
Mar 22, 2003 10:23 PM
poison
May 13, 2002 10:23 PM
citanest
Feb 28, 2002 11:03 AM
