RC injectors install issue
Old Mar 14, 2005 | 10:50 AM
ldanphanl's Avatar
Default RC injectors install issue
i got me a set of 370 RC incjectorrs for my D16A6 SOHC non-vtec motor, its a OBD-0 , is there any re-wiring that i need to do, inorder to get them to run properly, because it feels like my car is about to stall off everytime i release the gas pedal, and every once in a while check engine comes on. i was thnking that it might be a wiring issue or something, i heard that those with OBD-1 ecus needs rewiring but do the OBD-0 needs too also?
thanks ahead for any imput
AyuDan
Old Mar 14, 2005 | 11:58 AM
Mr.Death's Avatar
Default Re: RC injectors install issue (ldanphanl)
No extra wiring needs to be done. Sounds to me like your running rich. Your ecu was meant to operate the stock injectors which are considerably smaller than your rc injectors. In order to use bigger injectors you need to modify your air fuel ratio(afc/chipped ecu etc.)
Old Mar 14, 2005 | 12:00 PM
88crxvtec's Avatar
Default Re: RC injectors install issue (Mr.Death)
Be careful or your gonna wash down the walls, get an AFC or something u can tune with. Why are you running 370's, what kinda mods do you have?
Old Mar 14, 2005 | 12:21 PM
EP3_05's Avatar
It depends on if the injectors are low impedance(peak and hold) or high impedance(saturated)to whether you will need to do some wiring. Also like the other guy asked why are you running bigger injectors?
Old Mar 14, 2005 | 12:22 PM
ldanphanl's Avatar
nothing at the moment, i have boost sittine in the corner in my room and a V-AFC on top the shelf, just havnt put them in yet in, i was free one afternoon, and decided to install, what i have currently is intake header exhaust, thats it, Running rich eh, about to blow engine then?
Modified by ldanphanl at 1:34 PM 3/14/2005
Old Mar 14, 2005 | 12:24 PM
EP3_05's Avatar
Default Re: (ldanphanl)
Run the stock injectors until you boost the engine. The 370cc injectors will dump way too much fuel and the car will run like crap.
Mxl973
May 2, 2017 01:08 PM
boostedteg4dr
May 5, 2009 02:57 PM
ldanphanl
Mar 15, 2005 04:06 PM
b16powwer
Aug 15, 2003 12:07 AM
clu
May 14, 2003 12:27 AM
