rc injectors
Old May 13, 2003 | 04:24 PM
clu's Avatar
clu
Default rc injectors
i just bought some 310cc rc injectors on line and the guy says that most people use these injectors for their honda/acura, he used it in his audi a4. but when i got them the injectors dont seem to fit properly. the o-ring seems to be to big for the fuel rail. do i have to modify the injectors at all?? are the injectors for the audi a4 and gsr's compatible? any help is appreciated.
Old May 13, 2003 | 04:26 PM
keebler65's Avatar
Default Re: rc injectors (clu)
perhaps you need honda o-rings? just an idea. i was always under the impression that all RC injectors are the same but that each make/model uses different rings and spacers. i could be wrong though.
Old May 13, 2003 | 08:28 PM
clu's Avatar
clu
Default Re: rc injectors (keebler65)
i hope all the rc injectors are the same, but the clip doesnt seeme to fit either. can i shave some of it and click it in? will the clip send different signals to the ecu?
Old May 14, 2003 | 12:25 AM
DLOTYPER's Avatar
whats up man,,, what year motor are you running?? give me some more info on your setup,, i believe all rc injectors are obd1, because like me, 98 gsr motor,, i had to splice in obd1 injector clips for them, all the clips are the same by the way, i think if you can rig them in by shaving them that you'll be ok,,, also just make sure that they are saturated injectors unless you plan on running a resistor pack for peak and holds,,,,let me know
Old May 14, 2003 | 12:27 AM
DLOTYPER's Avatar
i am also sure that you need stock honda o rings for the tops and the correct maifold spacers for the bottom,,, your manifold should have those,, just make sure when you put the stock honda o-rings on the tops, to lube them with vaseline or some type of lube so you dont blow the seals, they rip mad easy
RACEPAK
Apr 29, 2010 01:42 AM
RACEPAK
Apr 29, 2010 01:41 AM
A13sechatch
Mid-Atlantic (Sales)
May 25, 2009 08:26 PM
