plx m300 wideband question???
Old Mar 13, 2005 | 08:07 PM
flip1199's Avatar
Default plx m300 wideband question???
Well i hooked up the m300 and connected the power wire to the power wire on the ecu and the ground to the ground wire on the ecu. also i have the battery in the trunk. so i go switch the batter to the on postion and the plx turns on even when the key isnt in the ignition. is that normal? it just displays " air". did i hook up the power wrong or something?
Old Mar 13, 2005 | 08:30 PM
93turbo16's Avatar
yea, you hooked it up to the constant 12V not the switched.
Old Mar 13, 2005 | 08:37 PM
flip1199's Avatar
Default Re: (93turbo16)
which pin in the 12v switch?
Old Mar 13, 2005 | 08:45 PM
93turbo16's Avatar
not sure, but you can check it with a voltmeter.
itsJDMyo
96
Feb 6, 2005 10:13 AM
Bulldogg83
Sep 23, 2004 06:37 AM
kenny84
Jun 2, 2004 07:50 AM
mskibbz-T
Feb 24, 2004 04:01 PM
1.8T_EG
Mar 17, 2003 05:04 PM
