coolant leak d14
Old Mar 13, 2005 | 01:24 PM
RACEPAK's Avatar
Default coolant leak d14
hello everybody
ok... i parked the car today after a hour of non aggressive driving. (no over heating/no smoke/no **** in oil)
i came back to the car an hour later and i saw a coolant puddle under the engine.
i took the car to the shop and did a coolant leakdown test (or however you call it) and it seems that the leak comes from behind the block... what could it be?
best regards moshik galimidi
Old Mar 13, 2005 | 01:29 PM
modedicebox's Avatar
Default Re: coolant leak d14 (RACEPAK)
worst case headgasket,thats what i replaced last night
goodluck
Old Mar 13, 2005 | 01:36 PM
SwapShopR's Avatar
No Sales Forums
If it's coming from behind the block, it may also just be a hose (there are many back there) I would look into that first b4 you start pulling stuff apart. Also does it leak on the side or the rear of the motor/ block? You could also have a water pump problem.
Old Mar 13, 2005 | 01:42 PM
RACEPAK's Avatar
Default Re: coolant leak d14 (SwapShopR)
its comming from the rear left...
Old Mar 13, 2005 | 01:48 PM
dohcVTECeg2's Avatar
im having this problem right now to. i have to change my water pump. lucky me it looks like i have my work cut out for me.
Yao Saechao
Mar 26, 2018 01:25 AM
OMG B16
Aug 27, 2005 08:20 PM
acteg94
Feb 10, 2004 05:44 PM
Allstar
Feb 26, 2003 05:55 PM
PrecisionH23a
Nov 17, 2002 01:13 PM
