---Sunk Sleeve---
Old Mar 12, 2005 | 09:19 PM
DragonosE's Avatar
Default ---Sunk Sleeve---
Here's my Q's. We dynoed my girlfriends setup not too long ago on a gsr 2.1 litre and blew the he ad gasket after the dyno session, well come to find out a sleeve sank very slightly about 1.5 thousanths. Is it exceptable to replace gasket and run again with indian sealer and bar's leak or tear down and resleeve. Opinions welcome.
Old Mar 12, 2005 | 09:34 PM
SJcivic's Avatar
Default Re: ---Sunk Sleeve--- (DragonosE)
resleeve if its a crappy job, deck it if you can get away with it
Rich
Old Mar 12, 2005 | 09:38 PM
regamaster's Avatar
What sleeves were you using in the motor?
Old Mar 12, 2005 | 10:44 PM
92TypeR's Avatar
FSAE
Default Re: ---Sunk Sleeve--- (LSVTEC_DC2R)
Who did the sleeving? I would start bitchin'
Old Mar 12, 2005 | 11:43 PM
ceLtic's Avatar
N/A wh0re!
Default Re: ---Sunk Sleeve--- (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">Who did the sleeving? I would start bitchin'</TD></TR></TABLE>
Old Mar 13, 2005 | 12:13 AM
DragonosE's Avatar
Default Re: ---Sunk Sleeve--- (SJcivic)
I was thinkin about decking it, but if it doesnt shift or sink any more it should seal ok with enough torque on the studs. &lt; "I'm hoping". Plus decking properly would require disassemble which is alot of down time and labor and she wont make nopi chick. Also if I was to deck it I would just have it resleeved at manufactures cost.
It's a golden eagle block, Please don't raise hell and flame the **** out of the company. It doesn't help my problem in any way.
Old Mar 13, 2005 | 12:37 AM
DragonosE's Avatar
I just noticed u have a couple bikes, I have an 04" R1 192 whp and the girlie has a 02' r6. You'll never guess where i'm from too! It will make u laugh.
Old Mar 13, 2005 | 07:03 AM
moto1320's Avatar
You can't just torque the head studs more. You just paid all of that money to have it sleeved, don't ghetto rig now....know what I mean. It will suck to have the downtime after all of the waiting but.... take the motor back. This happened to the h22 block of another local shop owners personal project. It had to be resleeved. The machinist had sleeved tons of blocks, unfortunately **** happens sometimes. The question now is will he back up his work. Sorry to hear about the trouble.
Old Mar 13, 2005 | 08:49 AM
92TypeR's Avatar
FSAE
Default Re: ---Sunk Sleeve--- (moto1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragonosE &raquo;</TD></TR><TR><TD CLASS="quote">It's a golden eagle block, Please don't raise hell and flame the **** out of the company. It doesn't help my problem in any way.</TD></TR></TABLE>
Why would we flame the sh*t out of GE, they do good work and have many success stories. Also, I am pretty sure GE warranties their blocks against their sleeves sinking. Before you try to do any work yourself, I would talk to GE and see what they have to say.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragonosE &raquo;</TD></TR><TR><TD CLASS="quote">I just noticed u have a couple bikes, I have an 04" R1 192 whp and the girlie has a 02' r6. You'll never guess where i'm from too! It will make u laugh.</TD></TR></TABLE>
192whp? YA now thats nuts. I **** myself enough with 140whp on my R1. I'm guessing you're from mission viejo ca U.S , because it says so next to your user name?
Old Mar 13, 2005 | 10:42 AM
boosted k20's Avatar
man, we r have n the same problem with one of our golden eagle sleeved blocks. one of the sleeves sunk a little which allowed coolant to get into the oil ,therefore thinning it out give n us less oil pressure due to the mixture of the water and the oil. we've been have n oil problems with this block for the longest time and figured out that the sleeve dropped cuz we put compressed air down the cylinder and found out this was the problem.
we called up golden eagle and they said they r not gonna replace the block. WTF!!!!!! i know there's a few golden eagle reps in here, so whats the deal about this. the motor hasnt even seen alot of miles. only went to the dyno and back. car actually spun bearings on the dyno due to the low oil pressure which resulted from the dropped sleeve. How r u GE people not gonnna warranty this??????
Old Mar 13, 2005 | 11:02 AM
AllMotorMadness's Avatar
If it's a GE sleeve just send it back they will inspect the block and if it's the sleeves then Vince will take care of it right away and fast service! I've had 3 blocks that went in for warranty and came back with all brand new ge hd sleeves.
Old Mar 13, 2005 | 02:19 PM
ShaunRR's Avatar
HT White Ops
Community Builder
GE has always warrantied for dropped sleeves in the past. PM, email, or call Vince.
Old Mar 13, 2005 | 02:40 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: ---Sunk Sleeve--- (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote"> car actually spun bearings on the dyno due to the low oil pressure which resulted from the dropped sleeve. </TD></TR></TABLE>
What killed your bearings was the coolant mixing with your oil and eating your engine bearings. Coolant chews the crap out of engine bearings, clearances are increased, oil pressure drops and rod bearings are spun...
Old Mar 13, 2005 | 03:25 PM
Default Re: ---Sunk Sleeve--- (rochesterricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">GE has always warrantied for dropped sleeves in the past. PM, email, or call Vince.</TD></TR></TABLE>
whose vince? is his sn vince? what about his email address???
Old Mar 13, 2005 | 04:07 PM
ShaunRR's Avatar
HT White Ops
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">whose vince? is his sn vince? what about his email address???</TD></TR></TABLE>
https://honda-tech.com/zero...95269
Old Mar 13, 2005 | 05:03 PM
DragonosE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto1320 &raquo;</TD></TR><TR><TD CLASS="quote">You can't just torque the head studs more. You just paid all of that money to have it sleeved, don't ghetto rig now....know what I mean. It will suck to have the downtime after all of the waiting but.... take the motor back. This happened to the h22 block of another local shop owners personal project. It had to be resleeved. The machinist had sleeved tons of blocks, unfortunately **** happens sometimes. The question now is will he back up his work. Sorry to hear about the trouble. </TD></TR></TABLE>
Well if the gasket goes again it wont immediately destroy everything. There's signs. smoke from exhaust, coolant mixing with oil, etc. My biggest concern is being able to make nopi chick. We were really looking foward to making this event. So I'm just curious if anyone has made 1.5 thou drop work before. After nopi I will disassemble and send it in to get warrantied. My other concern was people say there's alot of downtime on the inspection of the blocks. This doesnt make sense because it's a pretty straight foward deal. You know when u have done a poor installation and didnt press it correctly. I had eddie come down from RS machine and he was nice enough to mic it for me and he explained in detail what was going on. With no conflict of interest he told me it was faulty installation. Another thing that kills me about this is even if G.E warranties the block, I still get to pay for all that labor for installation of everything all over again, who is gonna reimburst me for that? No matter what happens I want to thank Eugene and Aron from "PROSTREET", in all honesty this whole project would have failed without the help and support of these two guys. I will never be able to put into words what these two have done for me. Oh, I'm from spanaway, Washington&lt; ghetto!
P.S HAPPY B-DAY ARON, ERIN&lt; HOWEVER U SPELL THAT ****
Old Mar 13, 2005 | 05:05 PM
DragonosE's Avatar
Default Re: ---Sunk Sleeve--- (AllMotorMadness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorMadness &raquo;</TD></TR><TR><TD CLASS="quote">
If it's a GE sleeve just send it back they will inspect the block and if it's the sleeves then Vince will take care of it right away and fast service! I've had 3 blocks that went in for warranty and came back with all brand new ge hd sleeves. </TD></TR></TABLE>
what was the turn around time, thanks.
Old Mar 13, 2005 | 05:26 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragonosE &raquo;</TD></TR><TR><TD CLASS="quote">I want to thank Eugene and Aron from "PROSTREET", in all honesty this whole project would have failed without the help and support of these two guys.</TD></TR></TABLE>
Off topis but are those the 2 guys from that mtv street racing show ?
But like everyone else said, don't rush the job, do it right, get the blocked fixed or else you might really pay in the long run
Old Mar 13, 2005 | 08:58 PM
DragonosE's Avatar
Default Re: ---Sunk Sleeve--- (90blackcrx)
Yah, Eugene was the guy in the 4 door integra. Amazing knowledge and a stand up guy. Aron, he's just the ****, funny bastard!
94lspower
May 9, 2007 02:53 AM
chet
Apr 15, 2007 01:24 PM
ssrcx94
Dec 18, 2005 10:05 AM
radeon
12
Dec 26, 2004 11:21 PM
