b16 head with gsr? or just plain ol gsr?
Old Mar 11, 2005 | 04:23 PM
esohsee's Avatar
Default help with build
hey i'm a newb with b motors i admit it... i've been with the d for a bit and got a deal for a gsr swap for 500 and heard that a b16 head would be good mated with the gsr block...
i going to build the bottom end with itr parts...
if i am going with the gsr head i'd go with jdm itr pistons, ctr intake cam w/ itr exhaust and itr valve train...
if b16 head... ctr pistons with ctr cams and itr valve train...
school me... thanks
Modified by esohsee at 7:42 PM 3/11/2005
Old Mar 11, 2005 | 04:25 PM
civicstar11's Avatar
bigger is better right, hmmm GSR! the gsr is bigger then the b16 head, ctr pistion is a good choise cuz it is has a bigger dome then ITR allowing for more compression.
Old Mar 11, 2005 | 04:32 PM
moto1320's Avatar
Go withthe first choice. it will be quick and streetable. don't use the CTR pistons, the compression ratio will be too much unless you are going to work over the motor to use it and buy Hondata or the like.
Old Mar 11, 2005 | 04:33 PM
esohsee's Avatar
Default Re: (civicstar11)
but with the gsr head the valves would hit with ctr pistons... again this is what i have heard... thanks for the quick response though...
Old Mar 11, 2005 | 04:52 PM
esohsee's Avatar
Default other options
or should i just get the itr pistons with a b16 head? thanks again
Old Mar 11, 2005 | 05:34 PM
well lets see, i have a gsr head, from JG and it clears fine.and i run CTR 25 over i run all motor LS vtec with the b18 a block and GSR head. i went with the GSR becuz it was a bigger head and LS becuz it had a bigger displacement.
Old Mar 12, 2005 | 06:46 PM
esohsee's Avatar
any other suggestions?
Old Apr 10, 2005 | 06:04 AM
jdmturbosol's Avatar
Default Re: (esohsee)
run the gsr stock
if you run the b16 head on the b18c1 bottom end you will be lowering your compression about .5 i believe
ctr pistons with this combo work good
but remember more compression=more torque
so right off the bat you will be loosing power putting that head on unless you run some higher compression pistons
Old Apr 10, 2005 | 04:07 PM
DelSolDon's Avatar
Default Re: (jdmturbosol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmturbosol &raquo;</TD></TR><TR><TD CLASS="quote">
so right off the bat you will be loosing power putting that head on unless you run some higher compression pistons</TD></TR></TABLE>
or mill the head and run a thinner head gasket, just another option
jdmmdg421
Jun 5, 2013 12:45 PM
Bedgoodmrb
Dec 20, 2009 07:36 PM
JDM_Frijoles
Sep 15, 2006 11:50 PM
dominicanito49
Jan 18, 2006 06:47 PM
