Is there a way to make vtec work and everything that goes with while using obd0
So i got a d16y8 in an obd0 car with obdo dizzy and pm6 ecu. Right now ive got the vtec
solenoid hooked up to a push botton switch that just turn the solenoid on and off when released. now ive read that in order for vtec to really work the vtec oil pressure needs to come on and the timing gets altered, advanced or retarded im not sure. Im wondering if theres a way i can get all three to work at the same time from a remote location eg. a switch in the car. Cause i dont want it to be on all the time only when im gonna race. I was thinkin a rpm switch for the solenoid and a stand alone ignition system for the timing but i dont know what i could use for the oil pressure, maybe it could tie into the rpm switch. I dont want the ignition system to be on all the time but to use the regular timing system for the car. Like i said i want it to all be hooked up to a flip switch in the dash. I dont know enough about the vtec system or ingiton to do this.
Can anyone please help me with this project. Also im gonna put a chip in the ecu you. if does this would it handle the boosted ignition problem for me ?
Thanks ... I love this site......
Hopefully one day i can answer other peoples questions like mine..........
It'll cost maybe $1.00... Only wire your going to need to run in order to run the PS9 ecu and Vtec using turboedit NG48, is the Vtec solenoid wire to pin A8 (auto lockup solenoid) which the PS9 will now use to activate Vtec at your desired RPM. CRX drew's got one all ready to go. Not sure what you were looking at spending but you'll be happier with TE over an RPM or manual switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srv3fender »</TD></TR><TR><TD CLASS="quote">that sounds nice but im still obd0 with a pm6. all the rewiring and new dizzy and harnesses and running wires through the firewall would cost a shhh load</TD></TR></TABLE>
???? They are still talking about an OBD0 Ecu and what do you think your "pressure switch, stand alone timing crap, etc" are going to cost? And they still won't do the job properly.....
You asked for advice and they gave you some good advice.... Personally, I say you should just do the OBD0-OBD1 conversion and get a P28 and really do it right!
ok, well lets say i did the conversion to obd1
what all exactly will i need
and keep in mind that i dont have any harnesses hooked up to the vtec solenoid just 2 wires coming out of it that turn it on and off
and i believe its an obd2 engine being a y8
and its an obd0 dizzy
why would you need to convet to obd1... they are offering you an obd0 ecu that will allow vtec to come on and not have to use your spiffy little "vtec-button"!!! if you want to conver to obd1 you are looking at much more money involved
OBD1 ECU for VTEC $100.00
OBD0 to OBD1 Conversion Harness $50-75.00 upwards of 150.00 (what I got)
OBD1 Distributor $200.00 dizzy king or 100 used
4 wire o2 sensor $125.00
probably knock sensor $???
Three options:
Chipped ecu
OBD0 pr3 ecu
Convert to OBD1
My 2 cents is to convert to OBD1 and run a p28 ecu
Chipped ecu
OBD0 pr3 ecu
Convert to OBD1
If you are obd0 and running a pm6... the ps9 will be a direct plug in.... with you needing to run ONE more wire
. Then using TE to chip it and boom.... vtec and very little hassle.
Currently all you are doing.. is switching the car over to the vtec(larger) cam lobe... and not giving it anymore fuel or changing timing.... its pointless to run an rpm switch without some fuel management adjusting. Vtec maps are run in a dual format, low cam fuel/high cam fuel.
. Then using TE to chip it and boom.... vtec and very little hassle.Currently all you are doing.. is switching the car over to the vtec(larger) cam lobe... and not giving it anymore fuel or changing timing.... its pointless to run an rpm switch without some fuel management adjusting. Vtec maps are run in a dual format, low cam fuel/high cam fuel.
you guys are so far behind the times...
PM6 now has 1 wire VTEC support with no hardware modifications, although you'll have to give up your AC because it uses the AC' clutch switch circuit to activate VTEC....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">you guys are so far behind the times...
PM6 now has 1 wire VTEC support with no hardware modifications, although you'll have to give up your AC because it uses the AC' clutch switch circuit to activate VTEC....</TD></TR></TABLE>
Thats cool... sounds like PGMFI.org to me. And you will have to make atleast one hardware modification, since the ECU will need to be chipped. That BTW is the answer to your fuel question too..... You can use the proper VTEC low/high cam fuel and ignition maps.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aragorn »</TD></TR><TR><TD CLASS="quote">
Thats cool... sounds like PGMFI.org to me. And you will have to make atleast one hardware modification, since the ECU will need to be chipped. That BTW is the answer to your fuel question too..... You can use the proper VTEC low/high cam fuel and ignition maps.....</TD></TR></TABLE>
But you'll have to splice the VTEC and non-VTEC maps together at the VTEC crossover point ... I don't think there's support for two separate sets of maps yet.
DO IT RIGHT OR DO IT TWICE
Rywire.com
Rywire.com
chico1784
Oct 27, 2009 11:25 PM
srv3fender
Mar 11, 2005 06:32 PM
green91
17
Dec 29, 2004 03:27 PM
