K&N High-Flow Performance Kits? Has anyone looked into these?
Old Mar 11, 2005 | 07:35 AM
Bbasso's Avatar
Default K&N High-Flow Performance Kits? Has anyone looked into these?
http://www.knfilterchargers.co...-3509
I'm looking for a intake for my R and stumbled on these, has anyone tried these or have any reviews of it?
thanks.
Modified by Bbasso at 9:07 AM 3/14/2005
Old Mar 11, 2005 | 07:40 AM
ZygSpeed's Avatar
Default Re: K&N High-Flow Performance Kits? Has anyone looked into these? (Bbasso)
... just another filter on a stick.
Old Mar 11, 2005 | 07:43 AM
IntegraLs94Cam's Avatar
Default Re: K&N High-Flow Performance Kits? Has anyone looked into these? (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">... just another filter on a stick. </TD></TR></TABLE>
Not to much more power then what you would get with a 20 dollar ebay intake ... switch out the intake with an K&N filter ... OMG almost the same
Old Mar 11, 2005 | 10:46 AM
splitime's Avatar
But that one comes with a MAF!!! thats worth like 20hp on an R
Old Mar 11, 2005 | 10:53 AM
RaVAGE00's Avatar
New User
Default Re: K&N High-Flow Performance Kits? Has anyone looked into these? (splitime)
Mogen intake ownz joo
Old Mar 11, 2005 | 11:02 AM
white rocket's Avatar
I ran a K&N intake on my Dakota 5.9 R/T and throttle response increased and butt dyno said it was worth the $275 I paid. Obviously a V8 is hardly a comparison.
The heat shield is a plus. If it's cheap enough I'd try it out. I can't see it being any better or worse than a generic short ram w/ shield. Good luck with it.
Old Mar 11, 2005 | 12:00 PM
KnowForever's Avatar
Default Re: K&N High-Flow Performance Kits? Has anyone looked into these? (white rocket)
they don't actually make one application specific for the R.
http://www.knfilterchargers.co....aspx
we sell tons of these things through advance but i seriously doubt it's worth the $250-$300 you're gonna pay for one that might fit, might as well spend a few more bucks and get a J's. Probably be better off just buying a generic ebay short ram and putting a K&N filter on it.
Old Mar 11, 2005 | 12:29 PM
Mario's Avatar
K&N used 3 cars from me to test fit & dyno the intake system you are inquiring about; GSR, Si, & Type R.
However, they were the earlier version with a plastic intake pipe (similar to Iceman intakes). Dyno gains were poorest on the B16A, better on the ITR, and best on the GSR. The heatshield is designed to sit flush with the roof of the hood, it is finished in black with some type of heat resistant coating and it makes a difference especially if you feed cool air via ducting into that area.
I'll try to find the dynocharts and scan them if I can, but it's been a long while so there's a chance they've been thrown away. Nonetheless, the
Old Mar 11, 2005 | 02:10 PM
Kapman38's Avatar
On my LS W/ B18C5 I have a K&N Typhoon Short ram intake...Look at my cardomain pics for a picture of it. Looks simialr except no heat shield...
Old Mar 11, 2005 | 02:12 PM
Bbasso's Avatar
Default Re: K&N High-Flow Performance Kits? Has anyone looked into these? (Kapman38)
do you like? is the sound anything worth writing home about?
Old Mar 11, 2005 | 02:25 PM
Splat's Avatar
Collector-o-Guns and Drinker
No Turbo Pig application. Weak
Though I'm happy with the K&N drop-in panel filter. No idea if it gained anything, but at least I can hear the turbo spool now
Old Mar 11, 2005 | 04:49 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
if you buy this i want to buy your stock air box. lemme know
Old Mar 11, 2005 | 08:09 PM
Kapman38's Avatar
It is much improved over stock, I have it hooked up to 68mm TB. But I have no comparison. Looking at getting memory fab wahle *****; since everyone raves about it... But The typhoon does make it load in full throttle and when vtec kicks in. But since I have used the typhoon on 2 different motors, I like it. Can not use CAI in Florida, lots of rain and standing water. On my LS It gave me better throttle response and actually increased my fuel mileage. On Highway got 36 mpg!!!! But since my swap, I have no reference. It was install on my JDM ITR motor from the start. But it dynoed at 180hp, 129tq... With all OEM internals... Seems pretty strong for an ITR motor...
Enough of my babbling, You can ride with me at Expo, and give me some pointers....
Old Mar 12, 2005 | 07:03 AM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kapman38 &raquo;</TD></TR><TR><TD CLASS="quote">
Enough of my babbling, You can ride with me at Expo, and give me some pointers....</TD></TR></TABLE>
Old Mar 12, 2005 | 09:47 AM
Opie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kapman38 &raquo;</TD></TR><TR><TD CLASS="quote">You can ride with me at Expo, and give me some pointers....</TD></TR></TABLE>
Better get a spare set of tires and pads and a lot of sleep before Expo
Old Mar 13, 2005 | 12:45 PM
Kapman38's Avatar
Default Re: K&N High-Flow Performance Kits? Has anyone looked into these? (opie)
I am working on a extra set of rims and will replace rotors and pads before i caravan to Expo...Y'all like the hawk pads, correct...going to get some brembo blanks.. Also going to bleed and replace brake fluid...
Sleep, hell, just give more beer...
Old Mar 13, 2005 | 07:47 PM
itr1244's Avatar
looks kinda wack. i'd stick to my J's
Old Mar 14, 2005 | 05:17 AM
Bbasso's Avatar
I like this guys answer
Old Mar 14, 2005 | 07:10 AM
tommymoose's Avatar
Default Re: K&N High-Flow Performance Kits? Has anyone looked into these? (Mario)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario &raquo;</TD></TR><TR><TD CLASS="quote">However, they were the earlier version with a plastic intake pipe (similar to Iceman intakes). Dyno gains were poorest on the B16A, better on the ITR, and best on the GSR. The heatshield is designed to sit flush with the roof of the hood, it is finished in black with some type of heat resistant coating and it makes a difference especially if you feed cool air via ducting into that area.
Yeah, the insulation properties of the whole system is what makes it good. I have one and if I pop my hood after driving my car for a little while, I can feel a difference when I put my hand on either side of the heatshield. Its a good 15 degree difference at least. Since the pipe itself is plastic too it doesnt absorb as much heat as a metal one. I give the intake a but I dont have much experience with any other ones.
Old Mar 17, 2005 | 12:40 AM
Bbasso's Avatar
Default Re: K&N High-Flow Performance Kits? Has anyone looked into these? (tommymoose)
Interesting...
If I can't find a mugen intake in my price range I guess I'll be a sucka and try this...
bibong
15
Oct 10, 2006 09:41 PM
tanklee
Apr 11, 2006 06:54 AM
stRodda
Jan 11, 2006 01:20 PM
josh200536
10
Jul 7, 2005 10:10 AM
5STAR3
Feb 26, 2004 07:47 AM
