vtec?
Ok, I dont know that much about ecu chips, so there for I need your help. In a spoon chip, I think the rev limiter is set to 8500, right? and the vtec is set to 4500. Is this ok to throw in a daily driver with just i|h|e? Or would you recomend getting some head work done first? And is there any long time effects of using one of these?
Unless you have some extensive tuning done on your car, don't change your VTEC cross over. Simple logic, VTEC is harder on the engine, so having VTEC engauged more is not the best of ideas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">Unless you have some extensive tuning done on your car, don't change your VTEC cross over. Simple logic, VTEC is harder on the engine, so having VTEC engauged more is not the best of ideas. </TD></TR></TABLE>
many newbs think they can get only a chipped ecu and think they are faster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa »</TD></TR><TR><TD CLASS="quote">
many newbs think they can get only a chipped ecu and think they are faster.</TD></TR></TABLE>
Thats exactly what I was thinkin. Oh, and a 3 foot wing, and a hood scoop so big, you could crawl in it. I'll be so much faster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sixgundone »</TD></TR><TR><TD CLASS="quote">
Thats exactly what I was thinkin. Oh, and a 3 foot wing, and a hood scoop so big, you could crawl in it. I'll be so much faster. </TD></TR></TABLE>
jo0 forgot the GT-R badge and a BigAzz VTEC sticker, and dont forget the 18" rims y0! That's like 40+ WHP gains
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTiVTo8000rpm »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gumbii »</TD></TR><TR><TD CLASS="quote">¿JDM yO! air freshner?...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnDThEnWuT »</TD></TR><TR><TD CLASS="quote">POWERED BY HONDA, instant 15 hps!</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec98 »</TD></TR><TR><TD CLASS="quote">WAIT.... You cant forget the SiR sticker and a big AR sticker on it </TD></TR></TABLE>
OH! OH! OH! AND!!! the fast and furious steering wheel cover.
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gumbii »</TD></TR><TR><TD CLASS="quote">¿JDM yO! air freshner?...</TD></TR></TABLE>
Knowing this thread went down the ******* already. You usually want to raise the rev limit not lower it.
Preprogrammed chips are as usefull as all the other **** you guys mentioned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLANBmotorsports »</TD></TR><TR><TD CLASS="quote">
Oh and to answer the question. Don't chip it until you have a reason.</TD></TR></TABLE>
I got my answer!!! thx alot man.
I dont understand why a lower vtec crossover is a bad thing (though probably this low it's going to lag). Is it not basically like having a larger cam in there when the lobes kick in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ragecloak »</TD></TR><TR><TD CLASS="quote">I dont understand why a lower vtec crossover is a bad thing (though probably this low it's going to lag). Is it not basically like having a larger cam in there when the lobes kick in?</TD></TR></TABLE>
The way you are thinking is not totally wrong. It's just that Honda programmed the ECU a certain way to gain the most out of the concept and power that VTEC produces. So once you start ******* with all of it without having enough engine work and tuning done, then it is just going to, esentially, cause a lose of power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Knowing this thread went down the ******* already. You usually want to raise the rev limit not lower it.
Get hondata or something.
