Vtec not working in my B16A2...HELP!!!
Old Mar 10, 2005 | 01:15 PM
Electron Si's Avatar
Default Vtec not working in my B16A2...HELP!!!
I don't know what to do! Vtec isn't working at all and I don't know why. Should I get an oil change, it has been about 4000 miles. Oh, and my Check Engine Light just came on. Don't know what to do. Help me please.
Old Mar 10, 2005 | 01:16 PM
Otherguy's Avatar
NASIOC.com
Default Re: Vtec not working in my B16A2...HELP!!! (Electron Si)
did you check the wires to make sure everything was pluged in? And your going to need to get something that will read your CEL
Old Mar 10, 2005 | 01:37 PM
Falqon's Avatar
I really don't understand the lack of common sense, vtec abuses your engine, high RPM's are harder, why in the world are you abusing your engine with a check engine light and it's possibly low on oil? What part of "my engine isn't running right" makes people want to rev it higher?
Search and fix the engine light.
Old Mar 10, 2005 | 01:40 PM
SOHC4life 96's Avatar
Default Re: Vtec not working in my B16A2...HELP!!! (Falqon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy92 &raquo;</TD></TR><TR><TD CLASS="quote">did you check the wires to make sure everything was pluged in? And your going to need to get something that will read your CEL</TD></TR></TABLE>
Yeah find out what that CEL is. Use a paper clip on the jump plug. Look at JDMlyfestyle's thread stickied up top.
Old Mar 10, 2005 | 02:02 PM
B16Drag's Avatar
WERD! Check the CEL and see which code(s) it throw. Then see if you can fix them. If not, reset the ecu and try again...
Old Mar 10, 2005 | 05:38 PM
timisyourfriend's Avatar
VTEC solenoid
Old Mar 10, 2005 | 06:11 PM
Sleek98's Avatar
Default Re: Vtec not working in my B16A2...HELP!!! (JZPerformance)
hasnt changed oil in 4k miles, i bet your low on oil so the vtec oil pressure sensor is saying "hey no oil, im not going to let vtec kick on" i have this problem also when my milage get up around 3k miles it comes on everyonce in a while. change the oil and you should be good.
Old Mar 10, 2005 | 06:26 PM
HATCHingMN's Avatar
check the ecu code and go from there.
Zackary Harris
K Series
Sep 7, 2018 09:38 PM
chadleehonda
Jun 30, 2010 07:35 PM
xtreme-customz
18
Dec 1, 2005 07:51 PM
inzaneN1
Dec 3, 2003 01:34 AM
Worangejuice
Nov 15, 2003 06:36 PM
