b20 motor replacement in type r questions
Old Mar 10, 2005 | 09:07 AM
skiwithcars's Avatar
Default b20 motor replacement in type r questions
Does anyone have any info on a b20 in a itr. If you have any info on how many miles it would last, power gain, or durability that would be great. I just need to know more about them before i more involved in it
Old Mar 10, 2005 | 09:43 AM
DOHCtorTHRUST's Avatar
Default Re: b20 motor replacement in type r questions (skiwithcars)
should be the same as a stock CRV...since it comes out of one...
if you're talking about building it then thats a different story
Old Mar 10, 2005 | 09:53 AM
Bradstard's Avatar
Just re-sleeve your B18C5 to 85mm. That's what I did.
Old Mar 10, 2005 | 12:44 PM
Default Re: b20 motor replacement in type r questions (Fat Bradstard)
im thinking of buying a 2000 itr that has a B20 Block 12:1 Arias Pistons - Eagle H Beam Rods and an itr head and iv herd that the rod ratio could screw things up at high rpms. I dont want the pistons rubing hard agains the block, but im not sure that would happen. I just dont want to be afraid of reving it hard and end up screwing up up bad.
Old Mar 10, 2005 | 03:08 PM
emotionisdead's Avatar
Very Emergency!!
i have a high comp b20/vtec in my 01 R.
Old Mar 10, 2005 | 03:18 PM
5STAR3's Avatar
Default Re: b20 motor replacement in type r questions (EmotionIsDead)
dont buy a built motor if you dont trust it, or who put it together.
Old Mar 10, 2005 | 03:20 PM
does it rev high and is it reliable?
Old Mar 10, 2005 | 07:58 PM
Very Emergency!!
well here is the thing i bought the motor built from a friend and i ended up breakin piston ring lands because of a lean condition. but before it blew it had way more power then the b18c5 and i revved it to 9000 with no problems. i am currently building the block to be better then before. i don't think that i will have any of the same problems. (i got a hondata instead of the shitty vafc)
Old Mar 11, 2005 | 04:48 AM
how many miles did it get untill it broke? and what kind of pistons and rods and crakn were u using?
j_the_guy
Dec 18, 2018 10:47 PM
EK SQUAD 425
Sep 18, 2007 06:48 AM
Bullet50
Sep 17, 2002 02:30 AM
done
May 23, 2002 03:29 PM
Phoenix GSR
May 20, 2002 04:52 AM
