Is it worth it?? B16A2 96-98 200$$??? (Don't mean to post is it worth it)
Old Mar 9, 2005 | 08:48 PM
civproject14's Avatar
Default Is it worth it?? B16A2 96-98 200$$??? (Don't mean to post is it worth it)
Ok soo I just got a call from a buddy that lives in Chicago. Right now I've been looking for a b16 and I have a 95 EG ex. It has no Transmission and it burns oil. But I planned on puting internals in it so i could run more boost. So thats not a problem so far its a good deal becasue i want to put a GSR tranny on it.
The problem is that its from a 96-98si civic and i have a obd1 and its a obd2 i think please correct me if im wrong but how hard is that to convert them or will they just work and i need a new ecu. Another thing is will my mounts on my D16Z6 work for this b16a2 I don't no if it comes with mounts. And the axles I will buy anyways becasue i want to hook up and to hook up you need stronger axles.
I'm sorry i no that were not suppose to post is it worth it kinda posts but i need to know becasuse I'm going to drive 10 hours for this engine. Also for a swap of this kind with everything is like 2500$$ and I planned on doing internals so im looking at about 3500$$ with a full swap otherwise this is going to be about 2000$.
Is it worth it??
Appreciate it guys thx.
Derrick
Old Mar 9, 2005 | 08:50 PM
Kendall's Avatar
A little OT, but there was no 96-98 Si (at least not in the US).
Old Mar 9, 2005 | 08:51 PM
Default Re: (Kendall)
ok my bad it must be a JDM well whatever it is it is a 96-98 b16a2 as far as i no my question is how much of a bitch to do the 0bd1 0bd2
Old Mar 9, 2005 | 08:53 PM
Default Re: (civproject14)
ok i no i sound like a total jackass but as im doing more searching it looks like all the USDM b16a2's are obd1?
Old Mar 9, 2005 | 09:00 PM
bump
ok lets say this is a obd2 can someone point me in the direction of how to do this because all i can find is a OBD2 to OBD1 does that mean obd2 engine will work with a obd 1 wiriing harness?
Old Mar 9, 2005 | 09:22 PM
skip.two's Avatar
all B16A2's are OBD2, and equipped in U.S. cars. they were made in 96-97 (Del Sol VTEC) and 99-00 (Civic Si). JDM Honda engines don't have numbers at the end (ex. B16A2). they would just be stamped as B16A.
Old Mar 9, 2005 | 09:30 PM
Default Re: (jL iLLuZiOnz 9)
ok so how hard would i be to go 0bd1 to obd2 basically what does it require? also is this a deal?
Old Mar 9, 2005 | 09:53 PM
^CX_d16's Avatar
your z6 harness plugs directly in, u need integra shift linkage and integra motor mounts, i think you will need to run a jumper harness and a chipped p28
Old Mar 10, 2005 | 07:28 AM
Default Re: (^CX_d16)
yeah I new the z6 harness went into the B16a2 obd1 but i wasent sure about the obd2 and as far as mounts go I didn't think they made b16 integras unless the ones they use for the rs,ls,gs would work for a b16a2 into a eg
Old Mar 10, 2005 | 07:35 AM
getnasty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civproject14 &raquo;</TD></TR><TR><TD CLASS="quote">yeah I new the z6 harness went into the B16a2 obd1 but i wasent sure about the obd2 and as far as mounts go I didn't think they made b16 integras unless the ones they use for the rs,ls,gs would work for a b16a2 into a eg</TD></TR></TABLE>
yes those mounts will work. even if the mounts are for a 1.8 or 1.6 aslong as they are dohc your fine
Old Mar 10, 2005 | 08:08 AM
beaterdriver's Avatar
yeah the mounts are interchangeable, i went from a jdm itr to a b16 in my car, i just swiched the mounts. i think the only mount we switched was the upper driver side mount. we had to use the itr mount on the b16
Old Mar 10, 2005 | 08:11 AM
Default Re: (beaterdriver)
Ok thanks I appreciate the feedback. Ok I was looking at a write up on B series swaps into the EG here on honda-tech and it looks like the EG harness will work on a OBD2 b16a2. But the dizzy and something else wont work so could i use mine on the 1.6 b16a2, as in my dizzy etc...
Appreciate H-T keep it comin.
Old Mar 10, 2005 | 08:32 AM
FuRiO27's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">A little OT, but there was no 96-98 Si (at least not in the US).</TD></TR></TABLE>sux
Old Mar 10, 2005 | 08:39 AM
Default Re: (ok27)
one more bump before class
Old Mar 10, 2005 | 08:45 AM
2lua's Avatar
use your stock harness and repin the dizzy. you can use the stock p28 ecu get it chipped with b16 program. your car is obd1 then stay with obd1 save you a lot of time and headache. so how much of a good deal are you talking about for this motor less tranny and burn oil.
Old Mar 10, 2005 | 08:50 AM
Default Re: (2lua)
yeah thats what I was thinking **** I don't know why couldnt it just be a damn JDM OBD1 well lets see...
Engine:200$
Transmission$800
Axles$300
Mounts: 50$ junkyard that is if it doesnt come with them.
New Rebuilt engine(Forged):1000$
MiSC. 400$
Total:around $3000 VS. 2500$ plus 500-1000$ in Forged internals???
Old Mar 10, 2005 | 08:58 AM
2lua's Avatar
sound like you heading on the right direction. well what are you waiting for then? get in your car with some friends and do a road trip. gl
Old Mar 10, 2005 | 08:29 PM
CivicHP's Avatar
200$ for engine wow that is a steal i wish i could get one for that price.
WeakSauceEJ8
13
Apr 15, 2011 11:50 AM
95_Civic_4dr
Jan 14, 2009 09:27 AM
YoungKadafi
10
Dec 23, 2006 10:29 AM
speedehatch
12
Aug 27, 2004 07:29 AM
GDM Z28
Feb 13, 2003 02:18 PM
