Head Gasket??
Old Mar 9, 2005 | 06:42 PM
99RedSi's Avatar
Default Head Gasket??
I'm swapping a B18C5 head onto my B16A2 block. I was wondering what head gasket should I use? I was going to go with Cometic and use 81mm .030" gasket is this ok for my setup?
Old Mar 9, 2005 | 06:54 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Head Gasket?? (99RedSi)
Yep that's fine since the B18c5 head is exactly the same head as the B16a2 head with only some slight porting and different cams etc.
Old Mar 9, 2005 | 07:01 PM
99RedSi's Avatar
Hey thanks a lot for the help I really appreciate it! This shouldn't raise or lower my compression right? That gasket is like OEM?
Old Mar 9, 2005 | 07:07 PM
00Red_SiR's Avatar
All Motor Mentor
The oem headgasket is .026 thick so a gasket that is .004 thicker would have a negligable effect on the compression ratio.
Old Mar 9, 2005 | 07:14 PM
boosted k20's Avatar
Default Re: Head Gasket?? (00Red_SiR)
the BSR head on the B16 block should raise the compression a little bit i think
Old Mar 9, 2005 | 07:17 PM
Big Teggie's Avatar
Just use an OEM VTEC headgasket.
Old Mar 9, 2005 | 07:19 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Head Gasket?? (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">the BSR head on the B16 block should raise the compression a little bit i think</TD></TR></TABLE>
He's using a Type R head not a GSR head.....same compression as B16 head.
99RedSi's Avatar
Default Re: Head Gasket?? (Big Teggie)
Does Cometic make custom head gaskets? Could they make .026 Multi layer steel gasket?
Old Mar 9, 2005 | 07:33 PM
00Red_SiR's Avatar
All Motor Mentor
They make all kinds of custom sized head gaskets (thickness) but realistically why don't you just use a stock B16a2 head gasket and get the .026 that way?
Old Mar 10, 2005 | 06:00 AM
99RedSi's Avatar
I probably should do it that way, but are the b16a2 head gaskets strong enough to hold lets say a 55 shot of nitrous?
Old Mar 10, 2005 | 06:23 AM
NJIN BUILDR's Avatar
Nothing wrong with the oem gasket.Lots of big hp engines out there using them.
Glenn
Old Mar 10, 2005 | 07:46 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99RedSi &raquo;</TD></TR><TR><TD CLASS="quote">I probably should do it that way, but are the b16a2 head gaskets strong enough to hold lets say a 55 shot of nitrous?</TD></TR></TABLE>
Hell ya....I'm running a 75hp shot on one now and know lots of other people running a lot more nitrous and boost on a stock headgasket without problem. A 55 shot is nothing...
Old Mar 10, 2005 | 10:34 AM
99RedSi's Avatar
Much respect to 00RED_SIR and for everyones help. I'm gonna get an OEM head gasket. Thanks!
bruisedcivic
Jul 16, 2011 12:29 PM
Ivan_JDM_hatch
12
Jul 13, 2007 06:44 PM
rmcdaniels
Nov 23, 2005 11:45 AM
p1ccoloz
Apr 21, 2003 09:41 AM
InfamousRS
May 31, 2002 03:27 PM
