reusing pistons?
Old Mar 9, 2005 | 12:30 PM
RHDintegXsi's Avatar
Default reusing pistons?
ive just spun a rod bearing on my b16a and amnow considering using the head for an lsvtec buildup. is it ok to reuse my pr3 pistons from the b16? i know fitment isnt an issue but im new to this and i dont want to throw in used pistons if thats a big no no. if its okay to reuse pistons what should i look for when inspecting them to see if they are still good..so far all i see is the normal carbon buildup on the tops. ill see how they look when i pull them out of the block
thanks in advance
Old Mar 9, 2005 | 12:44 PM
dohcter g's Avatar
Default Re: reusing pistons? (SINFULintegXsi)
Yes you can reuse pistons!!!! Just use your best judgment after you clean it.
Old Mar 9, 2005 | 09:25 PM
Default Re: reusing pistons? (dohcter g)
perfect..thanks for the quick reply dohcter
Old Mar 9, 2005 | 10:37 PM
Kendall's Avatar
It's never a bad idea to give them a few quick measurements with a micrometer, but used pistons are great. while they're out, it's not a bad idea to balance them either. All you need is a grinder and a postal scale.
Old Mar 9, 2005 | 10:42 PM
rough_draft's Avatar
i thought pr3 pistons bend after u take them off the rods making them unusable. anyone know of this?
Old Mar 9, 2005 | 10:56 PM
Kendall's Avatar
Default Re: (Lmaonade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lmaonade &raquo;</TD></TR><TR><TD CLASS="quote">i thought pr3 pistons bend after u take them off the rods making them unusable. anyone know of this?</TD></TR></TABLE>
That's a new one on me. I've seen plenty of sets of PR3's reused and never an issue. And based on build alone, if it was a problem with PR3's it would also be a problem with all other OEM B series pistons, but it's not.
Old Mar 10, 2005 | 07:51 AM
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">????????????
That's a new one on me. I've seen plenty of sets of PR3's reused and never an issue. And based on build alone, if it was a problem with PR3's it would also be a problem with all other OEM B series pistons, but it's not.</TD></TR></TABLE>
yeah it was just somethign i've heard with pr3 pistons. that once you take them off the rod they bend and can't be reused.. i'll search on it
Old Mar 11, 2005 | 06:32 AM
dohcter g's Avatar
It all depends on the machine shop that presses them off the rods.
civic-r11
Jan 29, 2007 01:46 PM
SPOOLINmatt
Jan 13, 2006 06:13 AM
