How does a thermostat help the performance of a car?
Old Jan 22, 2002 | 03:28 PM
Westrock2000's Avatar
Default How does a thermostat help the performance of a car?
Just that, I mean how can a lower temperature thermostat help a car? I guess I'm not real sure what they do exactly
Old Jan 22, 2002 | 04:08 PM
Erik_Pb_Foot's Avatar
New User
Default Re: How does a thermostat help the performance of a car? (Westrock2000)
It helps your engine run cooler... cooler = more efficient = more power... more or less it will help your stock engine last longer and will help cool your mod'ed engine to avoid overheating problems.
Old Jan 22, 2002 | 04:25 PM
MachAF's Avatar
Default Re: How does a thermostat help the performance of a car? (Pb_Foot)
I thought engines are more efficent when they run hotter, not so hot that the head gets warped.
I know that cooler air better for combustion because its more dense.
Usually you only put a lower temp thermo in if you live in tropical climates.
Correct me if I'm wrong.
[Modified by machaf, 6:29 PM 1/22/2002]
Old Jan 23, 2002 | 01:27 AM
Dirt's Avatar
Default Re: How does a thermostat help the performance of a car? (machaf)
I live in the tundra right now but i have a cooler temp thermostat.
It's just a little peace of mind in summer along with good life blood (Mobil 1) and clean coolant (I flush mine yearly).
Old Jan 23, 2002 | 09:41 AM
Tony the Tiger's Avatar
The thermostat only flows the coolant to the radiator sooner...it doesn't increase any cooling for that matter. If your car overheats after ie: 10 minutes of constant redlining, a low-temp thermostat is not going to do anything. But if your car has sufficient cooling, it's good to keep the engine running a bit cooler so the engine will be more responsive.
Old Jan 23, 2002 | 12:03 PM
BSQ's Avatar
BSQ
Default Re: How does a thermostat help the performance of a car? (Tony the Tiger)
This information about the Mugen thermostat was taken from King Motorsports website ( http://www.kingmotorsports.com/produ...ra/engine.html )
This thermostat has the operating temperature set lower than normal. It prevents engine power loss by minimizing rapid water-temperature rises under harsh conditions such as during circuit driving. The use of a flow-control-type valve prevents hunting, thereby achieving rapid stabilization of the water temperature (the engine warms up within a short period).
Operating temperature: 68°C (STD.: 76~80°C)
Full-throttle acceleration temperature: 81°C (STD.: 90°C)
[Modified by BSQ, 1:06 PM 1/23/2002]
KidZr0
19
Sep 1, 2011 01:28 PM
bikewithnoname
15
Apr 2, 2009 11:34 AM
vg30dett71510
Jul 6, 2003 09:28 PM
krshultz
Nov 30, 2001 10:58 AM
NewYorkTypeR
Jun 15, 2001 09:09 PM
