What type of paint/enamel to use on the inside of an oilpan?
Old Mar 8, 2005 | 02:08 PM
sheissrx's Avatar
Default What type of paint/enamel to use on the inside of an oilpan?
I just got this oil pan. It was tapped, and so some paint needed to be sanded off to weld.
Any Ideas on what to use?
Thanks
Old Mar 8, 2005 | 02:20 PM
specv5150's Avatar
Default Re: What type of paint/enamel to use on the inside of an oilpan? (sheissrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheissrx &raquo;</TD></TR><TR><TD CLASS="quote">I just got this oil pan. It was tapped, and so some paint needed to be sanded off to weld.
Thanks</TD></TR></TABLE>
I am not quite following you but WHY would you want to paint the inside of your oil pan????
Old Mar 8, 2005 | 02:45 PM
sheissrx's Avatar
Default Re: What type of paint/enamel to use on the inside of an oilpan? (specv5150)
because
1) rust will mix with the oil,
2) i dont know how the oil will react chemically with whatever metal they use for the pan. It comes fully painted from the factory for a reason.
Old Mar 8, 2005 | 04:07 PM
ReDHaTcHyGuy's Avatar
the inside of the pan doesn't relly need to be painted,,,,, there's oil inside kinda imposible for it to rust from the inside
Old Mar 8, 2005 | 04:14 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: What type of paint/enamel to use on the inside of an oilpan? (ReDHaTcHy97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDHaTcHy97 &raquo;</TD></TR><TR><TD CLASS="quote">the inside of the pan doesn't relly need to be painted,,,,, there's oil inside kinda imposible for it to rust from the inside </TD></TR></TABLE>
Old Mar 8, 2005 | 05:15 PM
hypnotixcrx's Avatar
this is a extremely sarcastic suggestion.do NOT use enamel...use OIL BAsed paint!your dumb
Old Mar 8, 2005 | 05:22 PM
No's Avatar
No
mix the paint with the engine oil before you start the car up...it will work its way down
Old Mar 9, 2005 | 02:07 AM
Rodney's Avatar
Default Re: (narib2oo1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 &raquo;</TD></TR><TR><TD CLASS="quote">mix the paint with the engine oil before you start the car up...it will work its way down </TD></TR></TABLE>
this also helps coat internal engine parts like rods, you don;t want those rusting away now do you?
Old Mar 9, 2005 | 02:10 AM
sheissrx's Avatar
Default Re: (Rodney)
I think he was being sarcastic. How about the OUTSIDE of the oilpan?
Old Mar 9, 2005 | 04:42 AM
Rodney's Avatar
Default Re: (sheissrx)
[QUOTE=sheissrx]I think he was being sarcastic....[/QUOTE
good catch danno... in all seriousness, just hit the outside with a little black rustoleum, and you will be good to go.
Old Mar 9, 2005 | 05:18 AM
B20badboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheissrx &raquo;</TD></TR><TR><TD CLASS="quote">because
2) i dont know how the oil will react chemically with whatever metal they use for the pan. It comes fully painted from the factory for a reason.</TD></TR></TABLE>
Sorry it is impossible for something with oil in contact with it for it to actualy rust. If it were to rust there would be a bigger problem than rust like water in your oil.
Hondaciv866
Jul 22, 2012 08:57 AM
caliskier
Apr 4, 2009 06:27 PM
gaydm.accord
Jul 24, 2007 01:19 PM
E-AT_me
Jan 24, 2006 05:40 AM
