skunk2 IM(dyno charts)
Old Jan 22, 2002 | 10:13 AM
maggsgsr's Avatar
Default skunk2 IM(dyno charts)
Does anyone have dyno charts of the skunk2 Intake manifold for a GSR?
Old Jan 22, 2002 | 10:50 AM
maggsgsr's Avatar
Default Re: skunk2 IM(dyno charts) (maggsgsr)
I would like to compare the gains,because I'm considering staying with the dual stage for everyday driving.
Old Jan 22, 2002 | 04:31 PM
Weston's Avatar
I don't know about the GS-R's, but all they do for LS'es is move about 8whp from 4k-5.5k to above 5.5k. The power at 4k-5.5k is as much as 8whp less than stock, but above 5.5k it's as much as 8whp more than stock. Not worth it on a LS, imo. I don't know what it'd do on a GS-R though.
Old Jan 22, 2002 | 05:17 PM
Eeepers's Avatar
New User
The dual stage is good for approximately 180 whp. If you are making close to that and you think the IM is a bottleneck, then upgrade. I wouldn't unless I had bigger cams, and a higher redline.
Old Jan 22, 2002 | 07:08 PM
Comtechgsr2000s's Avatar
New User
Default Re: skunk2 IM(dyno charts) (Eeepers)
I remember a dyno that Import Tuner had on a 95 GSR with an intake and exhaust. It gained hp in low range and lost a little in mid-range and then picked up again in the higher rpm range.
I hear that you need so many other parts to make this work. Does anyone have a picture of their Skunk intake manifold in their GSR?
Does it come with detailed instructions?
Old Jan 22, 2002 | 07:17 PM
Mr. Softee's Avatar
Default Re: skunk2 IM(dyno charts) (Mugenblkgsr2000)
i have the skunk2. its nice. it was easy to install.
-sam
Old Jan 22, 2002 | 07:20 PM
New User
Default Re: skunk2 IM(dyno charts) (94goldjungsr)
What other parts did you need? Can you post some pictures.
[Modified by Mugenblkgsr2000, 4:21 AM 1/23/2002]
Old Jan 22, 2002 | 07:21 PM
StinkyTofu's Avatar
how much was everything to get installed? i think someone on this board said it costed 750$, i sure hope thats not true
Old Jan 22, 2002 | 07:23 PM
Mr. Softee's Avatar
Default Re: skunk2 IM(dyno charts) (B-18C1)
its so easy folks! just do it yo self! take off old mani put new one on. you need some new parts for the throttle body, do a search to find that stuff. Search foos
Old Jan 22, 2002 | 07:29 PM
rockwilda's Avatar
750?!?! dang, someone made them grab their ankles.
lemme find my dyno chart b18c1 - AEM CAI and skunk2 mani only.
Old Jan 22, 2002 | 07:59 PM
rockwilda's Avatar
Default Re: skunk2 IM(dyno charts) (da_rockwilda)
yeah, i wouldn't recommend it on a stock motor.....i have ITR cams now and it feels great
Old Jan 22, 2002 | 08:13 PM
StinkyTofu's Avatar
i see, thats a funky looking dyno! it dips down then comes back up. Have you gotten a dyno recently? So it should be ok to get the skunk2 intake manifold after i get my itr cams installed and tuned and crap? Do you have any cel with the sk2 manifold?
Old Jan 22, 2002 | 08:17 PM
rockwilda's Avatar
yeah got me guessin too.
anyway, no CEL just make sure everything is hooked up right. but i did throw a CEL after my ITR cam install...im running a little rich and the o2 sensor isn't real happy.
and no i haven't gotten it dynoed sincei got my cams in, but i will soon though.
yeah i think it would be better to get the skunk2 after you get your cams...
Old Jan 23, 2002 | 06:43 AM
maggsgsr's Avatar
There are 3 dyno charts there which is which?
Old Jan 23, 2002 | 07:23 AM
stick's Avatar
ill try and get my dynos before and after s2m installed scanned tonight and post them
Old Jan 23, 2002 | 09:02 AM
maggsgsr's Avatar
Default Re: skunk2 IM(dyno charts) (stick)
That would be great,and even if someone has the dyno for the skunk IM before and after with ITR cams it would be great.
Old Jan 23, 2002 | 12:53 PM
rockwilda's Avatar
all the same,just different runs...mods are on the chart
Old Jan 23, 2002 | 12:59 PM
maggsgsr's Avatar
So its 3 runs all the same with intake and intake manifold?What was your baseline?
Old Jan 23, 2002 | 01:02 PM
rockwilda's Avatar
i never got one and till this day still regret not getting a baseline run
Old Jan 24, 2002 | 04:46 AM
maggsgsr's Avatar
Well thanks for the dyno runs,if anyone finds any other info feel free to add.
Old Jan 24, 2002 | 07:43 AM
wickedxboi's Avatar
u must be bored dustin. haha
[Modified by wickedxboi, 4:44 PM 1/24/2002]
Old Jan 24, 2002 | 08:19 PM
New User
Default Re: skunk2 IM(dyno charts) (wickedxboi)
The Skunk manifold isn't worth it.
Old Jan 24, 2002 | 10:00 PM
hybrider's Avatar
doesnt this disable the 2ndarys, thus a pretty damn good loss in trq downlow? with a good gain in mid, and better high end?
Old Jan 25, 2002 | 12:16 AM
HKxBlur's Avatar
I can't believe with those mods that u could say such a thing..
<understand that reluctance/ignorance = slower than me>
Yes, but it's not that big of a deal.. If u want to experience the feeling of no secondaries, disconnect the iab connector or unplug the line running to the vacuum unit/thingy/ufo.. If u want to experience the 5whp (stock), u gotta get the manifold..
Old Jan 25, 2002 | 12:46 PM
maggsgsr's Avatar
Default Re: skunk2 IM(dyno charts) (HKxBlur)
Yea i may change my mind,but i would rather have more usable tq and hp through most of the rev range,then have more for like 500 rpms,my opionion,same for the header,i would rather have a nice power curve threw most the rev range then the last 500 rpms.Thats were the header and manifold do better then stock IM and 4-2-1,the end of the rev range by a little.Note my car is not a highly modded ride,for modded rides go 4-1 and single stage.
b18Aaron
29
Apr 22, 2010 10:00 AM
tomlinson619
Apr 14, 2006 04:26 PM
spunky424
25
Apr 2, 2004 05:20 PM
matttegra
Feb 23, 2004 11:25 PM
B18C-EJ1
Jan 20, 2002 04:24 PM
