dyno sheet...
dyno sheet...
hey this was my dyno when i went to fall nationals...setup was:
1995 b18c1 block
1992 b16 head
US type R pistons
KMS black nitrated valves
skunk2 valves
skunk2 titanium retainers
skunk2 intake manifold
skunk2 program p28
wondering if you guru's out there could take a look and let me know if it looks alright..i currently got the skunk2 stage 2 cams in the car and wondering wut i'm putting down now...gotta get it tuned though...thanx alot
1995 b18c1 block
1992 b16 head
US type R pistons
skunk2 valves
skunk2 program p28
Re: dyno sheet... (spunky424)
you should ask a mod to move this over to the NA forum they will help you out alot more.
numbers don't look to shabby though, if you got hondata and got it tuned good you could probably net more power
skunk2 stage 2's are gonna need more than 10.6:1 compression to work good. your gonna have shitty midrange, but you will have decent peak (max rpm) power.
what is ur current set up? from intake to exhaust.. list everything.
Re: dyno sheet... (Downey)
thanx for the replies.i had posted this in the NA motor and got no responses...at the time of the dyno the setup was as listed from above:
1995 b18c1 block
1992 b16 head
b16 sir2 cams
US type R pistons
skunk2 valves
skunk2 program p28
stock b16 header
short ram intake
msd coil
my current setup now includes the following additions:
jdm 4-1 header
test pipe
skunk2 stage 2 cams
yea i know i'd benefit from higher compression..but i gotta deal with wut i have right now...any more input would be much appreciated...
all of this is in a 92 eg hatch..
1995 b18c1 block
1992 b16 head
b16 sir2 cams
US type R pistons
skunk2 valves
skunk2 program p28
stock b16 header
short ram intake
msd coil
jdm 4-1 header
test pipe
skunk2 stage 2 cams
I don't know about the torque curve, but the power looks very linier. The skunk2 prog must be working out good for your setup. Looks like it's starting to cut up at 7.6-8.0K. Could be spark blow out. What do I know? What plugs are you using?
Re: dyno sheet... (Icey112)
i had the b16 sir2 jdm cams since the cylinder head was the jdm sir2 motor, i have a b&m fuel pressure regulator and gauge set at 40psi right now...
i think that header may have held you back alil. seriously though i think those numbers are decent for an untuned motor. get it tuned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icey112 »</TD></TR><TR><TD CLASS="quote">im doing the same thing poor mans type r my comp.11-2-1 and im running skunk2 stage 1 haven't been to the dyno yet.</TD></TR></TABLE>
wut pistons you running to get a 11.2 compression.. i had a mugen headgasket before which bumped my compression to like 11.1...but the gasket leaked so i went with the oem gasket...
yea tuning is next....i jus spent a few bucks on the jdm header and test pipe to openup the exhaust system...so i'll be being a hondata s200 soon...
Re: dyno sheet... (slammed_93_hatch)
with compression at 11.2 would i have any problems with pinging on 93 octane? i'm thinking about gettin gmy head milled and using a 2 ply headgasket which would give me about 11.2 ....
what do you consider a poor mans type R?
in my camp the LSVTEC was a poor mans type R we did one in late 97
Re: dyno sheet... (Huggy Bear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist »</TD></TR><TR><TD CLASS="quote">I think a poor mans R is a b18c block with a b16 head</TD></TR></TABLE>
yep
yep
Re: (slammed_93_hatch)
Those #'s do look rather low for your setup. Definately invest in a new header because the stock one IS holding it back. I've seen dyno sheets that had only 11.1:1 cr with the stage 2's and still lay down mid 180's to low 190's.
Re: (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 »</TD></TR><TR><TD CLASS="quote">Those #'s do look rather low for your setup. Definately invest in a new header because the stock one IS holding it back. I've seen dyno sheets that had only 11.1:1 cr with the stage 2's and still lay down mid 180's to low 190's.</TD></TR></TABLE>
that dyno was taken before skunk2 stage 2 cams were in the car...when dynoed i was running b16 cams
