Hesitation/jumping tach(searched)
Old Mar 7, 2005 | 11:54 AM
stRodda's Avatar
Default Hesitation/jumping tach(searched)
car starts normally, and drives normally under 3000rpm. in any gear, when i hit about 3k the tach starts to jump around. if i give it more gas or take the rpm's higher the car starts to hesitate or what sounds kinda like misfiring.
i checked the plugs, cap and rotor... all looked clean. whats going bad?
Old Mar 7, 2005 | 12:16 PM
98TypeSH's Avatar
Default Re: Hesitation/jumping tach(searched) (stRodda)
Sounds like you got the dreaded h22 hesitation.
First id say check your timing and look for any possible vac leaks. This is some crazy problem that has been plaguing most of the h22 community. My car did it at one point as well. I double checked all my vac diagrams and re routed all of them.
Old Mar 7, 2005 | 03:41 PM
PrettyLude's Avatar
sounds like symptoms of a bad ignitor
Old Mar 9, 2005 | 05:17 AM
boostlude's Avatar
I agree with PrettyLude sounds like what happened to me. The tach jumped all crazy but the rpms seemed normal then the car died and wouldnt start. Checked everything like you said replaced the ignitor and its fixed
Old May 26, 2005 | 07:29 PM
tc_gts's Avatar
Default Re: Hesitation/jumping tach(searched) (boostlude)
me to i replaced ignitor and it was fixed but then later on when i drove the car like a hours later the tach started jumping agian
Old Jun 8, 2005 | 07:43 AM
CRXified's Avatar
Default Re: Hesitation/jumping tach(searched) (tc_gts)
im having teh same problem with my b16 right now and from what ive rear its teh ignitor. im going to take it out and tighen the connections a bit adn see if that helps.
Old Jun 8, 2005 | 08:03 AM
syntax.'s Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">sounds like symptoms of a bad ignitor</TD></TR></TABLE>
yup, just happened to my h23. i replaced the whole dizzy with a re-manufactured one instead of just getting the ignitor. no problems since.
Re-manuf one cost me about $200.
JasonST
Aug 12, 2006 01:23 PM
e-Roc
Jul 3, 2006 02:55 PM
monalisa overdrive
Sep 4, 2005 10:43 PM
chrgdlude1
Mar 13, 2004 12:05 PM
RS1995
Jun 8, 2002 08:17 PM
