Hydro / Cable Whats the difference?
Old Mar 6, 2005 | 05:53 PM
ldanphanl's Avatar
Default Hydro / Cable Whats the difference?
can someone explain to me the difference in the two? Hydraulic and Cable Transmission.
Old Mar 6, 2005 | 06:07 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Hydro / Cable Whats the difference? (ldanphanl)
cable transmission useds a cable attatched to the tranny from the clutch petal to enguage the clutch
while Hydrolic transmission uses fluid pressure (similar to brakes) to enguage the clutch.
Old Mar 6, 2005 | 07:56 PM
Civic138's Avatar
Default Re: Hydro / Cable Whats the difference? (HatchBox)
also doesn't the hydro tranny automaticly adjust the clutch while the cable it has to be manually adjusted every one in awhile?
Old Mar 6, 2005 | 08:08 PM
kjcarlos's Avatar
Cable trannys have crummy synchros when compared to hydro trannys.....if you've ever disassembled both you would be able to see the difference....the hydro synchros are HUGE when compared to the cable synchros..
Old Mar 6, 2005 | 08:50 PM
Civic138's Avatar
Default Re: (kjcarlos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kjcarlos &raquo;</TD></TR><TR><TD CLASS="quote">Cable trannys have crummy synchros when compared to hydro trannys.....if you've ever disassembled both you would be able to see the difference....the hydro synchros are HUGE when compared to the cable synchros..</TD></TR></TABLE>
yea that's true, but it depends on what tranny it is, i mean if you have a (just makeing a statement) 91 ls tranny and a 94 ls tranny, the synchros in the 94 would be thicker mainly to handle the hp increase, there are also other factors that goes into it also.
sevwen7
Jun 4, 2010 05:37 PM
turbo-crx
Oct 7, 2008 02:45 PM
honda-tech
Nov 14, 2004 02:12 PM
robbin
Apr 14, 2004 12:42 PM
crxguy05si
Jan 24, 2003 07:40 PM
