Wire Harness with GSR swap
Old Mar 6, 2005 | 02:35 PM
civic_speed99's Avatar
Default Wire Harness with GSR swap
Sorry I searched, but it was down. I am getting parts together to put an obd1 gsr swap in my 99 ex. Can I just get an obd2-obd1 adapter and use my current harness, or do I need to get the stock gsr harness to run the p72 ecu?
Old Mar 6, 2005 | 03:37 PM
Lmgrcivic's Avatar
Default Re: Wire Harness with GSR swap (civic_speed99)
you can get the harness to run the obd1 ecu but some of your plugs on the engine harness are going to be different like the plugs for your injectors and such
Old Mar 6, 2005 | 04:11 PM
Do you know exactly what plugs I would have to change? How hard is it?
Old Mar 6, 2005 | 05:31 PM
Bump
Old Mar 6, 2005 | 05:36 PM
locash's Avatar
Use the 99 EX engine harness with an obd2b-1 ecu adapter, and change the following plugs on your engine harness:
Distributor
Injectors
Alternator
Intake Air Temp Sensor
Add the IAB plug and wiring.
That should be about it, unless I am forgetting something, which is possible..
Old Mar 6, 2005 | 07:03 PM
Thanks alot. In order to change them, do I just cut the old ones off and splice then new ones on. Dumb question.
Old Mar 6, 2005 | 07:52 PM
locash's Avatar
Default Re: (civic_speed99)
Thats pretty much the way to do it..
Good luck..
BOOSTEd2
13
Mar 28, 2011 04:56 PM
prime-R
Mar 1, 2009 12:17 PM
mrjenkins
Jul 4, 2008 01:03 PM
scivicex99
Dec 15, 2004 12:41 PM
turkdog
Mar 7, 2003 12:27 PM
