accord with H22
Old Mar 6, 2005 | 02:07 PM
JDMHatch101's Avatar
Default accord with H22
i have a 94 accord lx. i just recently swapped a 93-95 jdm prelude H22A. im using the motor, tranny, and P13 ECU. i got everything done and the car starts (barely). its got a new dizzy, rotor button, cap, plugs, and plug wires. the problem is the car runs choppy as hell. wont rev past 3K. all vacum lines are good and in right order. any advice would be greatly appreciated?
Old Mar 6, 2005 | 02:13 PM
v4lu3s's Avatar
RTFM
is your check engine light on?
Old Mar 6, 2005 | 03:38 PM
Lmgrcivic's Avatar
Default Re: accord with H22 (JDMHatch101)
yeah if you have any cells then it wont let it rev past that have a friend that had the same problem and to fix all the cells first
Old Mar 7, 2005 | 01:35 PM
Default Re: (v4lu3s)
yes the CEL is on but how do i check it??? thanks for the help guys
Old Mar 7, 2005 | 02:33 PM
DFW's Avatar
DFW
Default Re: (JDMHatch101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMHatch101 &raquo;</TD></TR><TR><TD CLASS="quote">yes the CEL is on but how do i check it??? thanks for the help guys </TD></TR></TABLE>
Everything is in <FONT COLOR="red"> <FONT SIZE="2">HERE </FONT></FONT>
Old Mar 8, 2005 | 09:10 AM
EP3 CTR's Avatar
accord and preludes have one wire that is different...you need to switch the egr wire and i think some heater wire at the ecu. its been a while since i had to do it but i remember it sounded and ran like crap before i switched them. i found this out in one of those h22a swap guides on the net im sure you can find it if you havent switched them already. i also had a problem with the egr on my h22a. my personal reccommendation as a h22a accord owner: block egr, get a obd1 gsr ecu(no egr) and a vafc, disable the secondary runners so theyre open all the time. i went through months of headaches with my swap and idling problems...its best to go all out. check out my accord, the link is in my signature, good luck and holla if you got a ?
Old Mar 18, 2005 | 03:17 PM
anyone else got anything? we cant figure this thing out?
Old Mar 19, 2005 | 01:39 PM
jakeiscool's Avatar
Banned
...grounds...?
Old Mar 19, 2005 | 03:01 PM
IHateJDM's Avatar
What is the code?
Old Mar 20, 2005 | 06:29 AM
grounds are good, and it wont give any codes, the cel comes on and stays on.
Old Mar 20, 2005 | 08:16 AM
v4lu3s's Avatar
RTFM
sounds like you got a bad ecu or you plugged in stuff wrong on the engine, like putting tps and egr plugs on teh wrong places or something.
Old Mar 20, 2005 | 06:29 PM
ok guys i got all that **** fixed now when i drive the car it feels like the axles are binding up. i can drop the throttle and it wont pickup like it should. any ideeas on that?
H22_aCCoRd_07
Jun 24, 2009 05:19 PM
khunt0012
Apr 5, 2006 09:56 AM
SPOON_FED_DC_2
Apr 17, 2005 01:50 PM
JDMHatch101
Mar 28, 2005 09:39 AM
spettinger
May 18, 2004 03:44 PM
