TIRED OF THIS NOISE...
im tired of hearing this noise coming from my motor...especially around 3000rpm to 4000rpm...when i slightly press on the gas ..it makes this weird whistling sounds...very irritating...it started happening after i bent some valves months ago..now its fixed..but that stupid noise is stilll there..what could the problem b...need help pls.............denx
A short ram Intake will do it as well as a few 3" diameter CAI's. Another problem that can cause this if you upgrade your TB to a bigger size and do not port match the IM!
From: americas finest, calee fourn ya, united states
did you have an intake before you had your valves fixed if yes and you didn't hear the whistling try to pinpoint exactly where the whistling sound is coming from then troubleshoot from there.
nah i kno for sure its not the intake becuz it only happens around 3000 rpm...and it only accured after i bended my valves..i have short ram ever since day one...im also assuming that its my intake manifold gasket/... becuz when i installed my skunk im....it was leakin coolant and i just mikey mouse it to stop leaking..maybe some air leak....so prolly after that misshift and bent valves..and happens...HELP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PAndADc2 »</TD></TR><TR><TD CLASS="quote">nah i kno for sure its not the intake becuz it only happens around 3000 rpm...and it only accured after i bended my valves..i have short ram ever since day one...im also assuming that its my intake manifold gasket/... becuz when i installed my skunk im....it was leakin coolant and i just mikey mouse it to stop leaking..maybe some air leak....so prolly after that misshift and bent valves..and happens...HELP</TD></TR></TABLE>
It's your intake/T-body.
Put your stock air box on and it will go away.....Use it to your advantage and whissle at the girls
mothafu***r!!! i already told you it was your intake.. dont u hear mine biotch!? dont worry about no whistling noise!! get your <U>car out </U>of the <U>garage</U> and race it!!!
DSBP1
18
Jul 7, 2007 07:51 PM
Puffwheat
Feb 13, 2004 09:59 PM
