Vtec solenoid question...
Old Mar 5, 2005 | 01:16 AM
_Cyclone_'s Avatar
Default Vtec solenoid question...
The cap thing on my Vtec solenoid has some ugly surface rust that I want to get rid of when I do the full underhood cleanup in the spring. Can someone explain to me if and how it comes apart? I've seen people mention something about a vtec solenoid filter... is there one on my y8? Is there any other kind of service I should be doing to the solenoid while it's off?
Pics, as usual. They always help me to explain what I'm talking about.
Old Mar 5, 2005 | 01:21 AM
CRXDrew's Avatar
The filter is in the section where the solenoid actually connects to the head. You can just clean that filter with some brake cleaner.
The cap section, I believe is actually the solenoid machanical part itself.
Once you remove the solenoid the cap can be easily sanded and painted.
Old Mar 5, 2005 | 01:24 AM
_Cyclone_'s Avatar
Default Re: (CRXDrew)
Good. So that cap actually comes off of the solenoid? How difficult is it? It's hard to tell...
Old Mar 5, 2005 | 01:38 AM
Cruiser G's Avatar
Default Re: (CycloneBlue_1.6EL)
If you want to clean it you should probably just take off the whole solonoid assembly with those 3 bolts and clean it like that. I'm not sure that the cap comes off.
Old Mar 5, 2005 | 01:53 AM
_Cyclone_'s Avatar
Default Re: (Cruiser G)
I was going to take the solenoid off to clean the filter anyways, I just thought it'd be easier to clean that cap if you could seperate it from the unit.
EJ8_Man
Honda CR-V & Element
Sep 23, 2016 08:13 PM
Charlie Moua
May 24, 2009 07:40 PM
bonstokLS
Jan 20, 2009 07:16 PM
rollindelsol
11
Dec 9, 2006 04:53 PM
Xymox007
Sep 19, 2004 07:57 AM
