Short shifter adapter for H22a, cause more harm than good on transmission?
Old Jan 21, 2002 | 05:06 PM
se93's Avatar
Default Short shifter adapter for H22a, cause more harm than good on transmission?
Does the short shifter adapter cause more harm than good on the H22a transmission? Just curious to know. Would the transmission be better off without it?
Thanks,
Mark
Old Jan 21, 2002 | 05:11 PM
mike's Avatar
H-T Order of Merit
Default Re: Short shifter adapter for H22a, cause more harm than good on transmission? (se93)
it's not going to hurt your tranny, but it will rip your shift boot.
/me has a ripped shift boot.
mike
Old Jan 21, 2002 | 06:36 PM
schwett's Avatar
New User
i tried the DC and the Neuspeed, both sucked. I was so excited when i took the Neuspeed off and could shift smoothly and without rubbing again. No amount of carving out the shift boot frame helped.
Old Jan 21, 2002 | 06:49 PM
se93's Avatar
Default Re: Short shifter adapter for H22a, cause more harm than good on transmission? (schwett)
That is true, especially in my case with 5th and reverse gear. I was considering shaving off some of the shift boot frame, but if you tried and it did not work, then no use in doing it. Hmmm, maybe that is why my reverse gear got permanently jammed and i had to take the tranny apart and get a new reverse gear ball bearing and fix the synchro.
Mark
Old Jan 22, 2002 | 10:31 AM
sensaiGen5's Avatar
replacing your shift boot is the least of your worries.
I had to replace the Shift cable's and replace the syncro in 3rd and 5th!!
Its not worth it dude!!!
Just shift faster
Old Jan 22, 2002 | 10:32 AM
laughinxxx's Avatar
New User
Default Re: Short shifter adapter for H22a, cause more harm than good on transmission? (sensaiGen5)
Just shift faster
agreed.
Old Jan 22, 2002 | 03:17 PM
nicksweetlude's Avatar
Default Re: Short shifter adapter for H22a, cause more harm than good on transmission? (laughin2.2)
i hate to contradict but, i have a dc short shifter and yes i did have to grind the plastic thingy under the boot, and yes it did rip my shifter boot but i had no idea how or where exactly to cut it. so i bought a new shifter boot (bout 60 bucks) and did it right. now i have no rubbing, no torn shifter boot and super short fast shifts. only problem is how do you make it make that "cool" fast and the furious shifter sound? anyone else noticed it?
Old Jan 22, 2002 | 03:22 PM
schwett's Avatar
New User
Default Re: Short shifter adapter for H22a, cause more harm than good on transmission? (nicksweetlude)
http://www.preludeonline.com/showthr...ighlight=short
Old Jan 22, 2002 | 11:05 PM
BryanS's Avatar
New User
I bought an OBX (ebay off brand) short shift adapter and figured it to be a dc sports knock-off. I installed it on my 4th gen and I like the way it feels. It doesn't rub at all, reduced the throw a bit, and the shifts feel the same. I don't know if the shape is a bit different or it's since I have it on a 4th gen, but I have no problems with it and didn't have to carve up anything in my car.
SHG_Claudio
25
Nov 2, 2010 12:45 PM
BB1LOViN
Jul 11, 2008 02:28 AM
Trian
Jun 19, 2006 02:33 PM
hatchback
Jan 4, 2003 11:08 PM
se93
Jan 7, 2002 07:58 AM
