car dies when starting
Old Mar 3, 2005 | 11:06 AM
zexifiedlude's Avatar
Default car dies when starting
aight this is the second time it happend so now im scared. i get out of school today and turn my car on, when i let out the clutch the car dies!! when i try to start it again and let the clutch out slowly rumbles but doent die...any one know whats up with this?? i dont know if this matters or not but i have a remote starter on my car so i can start it without the clutch. thanks
Old Mar 3, 2005 | 01:16 PM
T-King's Avatar
Default Re: car dies when starting (zexifiedlude)
Sorry to sond like an *** but you do know how to drive a manual car ....right?
Old Mar 3, 2005 | 01:29 PM
yeah i do, this is all in neutral
Old Mar 3, 2005 | 03:22 PM
T-King's Avatar
Default Re: (zexifiedlude)
Ok very sorry, is really hard to get in to different gears every now and then, like when going from reverse to 1st, etc.? If it is you may have a bent shifting fork, or a binded cabel.
_______________
92 Si 4WS JDM H22a
Old Mar 3, 2005 | 04:17 PM
The Phil's Avatar
Default Re: (HondaLude92)
Actually um...do you have gas in the car? When mine is almost out of gas it'll start but die when i let the clutch out.
Old Mar 3, 2005 | 04:32 PM
yeah i have a full tank pretty much
Old Mar 3, 2005 | 06:20 PM
A Blue Lude's Avatar
Second time that it happened? What was the cause of the first?
Old Mar 3, 2005 | 06:21 PM
Ludster's Avatar
Default Re: (Featherfire)
Would Crank Walk cause this? due to low idle?
Old Mar 3, 2005 | 07:10 PM
Hawkze_2.3's Avatar
Default Re: (Ludster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ludster &raquo;</TD></TR><TR><TD CLASS="quote">Would Crank Walk cause this? due to low idle?</TD></TR></TABLE>
Preludes don't have DSM engines......well, none that I know of.
Old Mar 3, 2005 | 07:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Featherfire &raquo;</TD></TR><TR><TD CLASS="quote">Second time that it happened? What was the cause of the first?</TD></TR></TABLE>
by second time i mean it dieing the second time like the day after it happend the first time
Old Mar 3, 2005 | 08:35 PM
jamey220's Avatar
im not trying to tell u what to do but these are ellegal on five speeds i had one on my and i took it off simply because i forgot to take it out of netrual and started it and when it tried to crank it ran into my house, and but the other reason is because one night i was at a street race and parked behind this truck well when i was walking back to my car i hit the start button and it started, it ran into the back of this guys and i had to pay for it, but luckly there wasnt anybody behind the truck i had said that i would never leave it in gear and look what happened to me.
Old Mar 3, 2005 | 08:45 PM
The Phil's Avatar
Default Re: (jamey220)
What are you talking about? And what does that have to do with anything? These arent s2ks...we don't have a start button.
Old Mar 4, 2005 | 06:46 AM
chrisgags13's Avatar
Default Re: (xthephilx)
ok maybe ur remote starting is ******* around. disconnect and try .. if thats not it then check ur neutal safety switch like the guy was rambling about above...if thats not it maybe its something wrong with the tranny/clutch/flywheel/shifting cables/forks/ thats causing the engine to stall
RemerLex11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Preludes don't have DSM engines......well, none that I know of.</TD></TR></TABLE>
basically any turboed car can have crankwalk......right?
Old Mar 4, 2005 | 06:47 AM
also check your clutch fluid and make sure your master and slave are working
Old Mar 4, 2005 | 12:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zexifiedlude &raquo;</TD></TR><TR><TD CLASS="quote">
by second time i mean it dieing the second time like the day after it happend the first time</TD></TR></TABLE>
yeah the day it did it the first time. like today was it didnt do it at all (knock on wood) and i checked all my fluids and everything seems to be fine, i have i new clutch and flywheele and tranny, imma see if it was my cable, never thought to check that. thanks
Old Mar 4, 2005 | 02:16 PM
i heard something about an ignition switch recall? anyone think that may have something to do with that&gt;?
ale_malo
Feb 16, 2014 06:33 PM
driftahboi
Dec 3, 2007 10:35 PM
BIGthings
13
Feb 19, 2006 09:15 PM
jdm22vtec
Apr 15, 2004 06:23 AM
OneSlyTeg94
Jul 11, 2002 11:11 AM
