Cost for sleeving
Old Jan 21, 2002 | 02:05 PM
teg92's Avatar
Default Cost for sleeving
I can get a blown long block LS for $30 (don't ask). Even if it ends up being completely finished it's still not a loss. So anyway my question is I am building a head right now and down the line I had planned for a B20z bottom end. I am wondering instead of this I can just resleeve this LS, get a set of OEM B20z or endyn or JE pistons, new bearings and be off with it. I'm wondering what costs are involved with having the engine sleeved. TIA
Old Jan 21, 2002 | 02:52 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Cost for sleeving (teg92)
Golden Eagle Manufacturing (www.goldeneaglemfg.com) sleeves them for $785 or so. I the FI forum, I believe someone is sending out multiple blocks to have them done at $585 each.
I could have helped you cuz my friend was about to send 4 of his blocks, mine, and one extra (yours), but the plan fell through.
Old Jan 21, 2002 | 03:11 PM
teg92's Avatar
Default Re: Cost for sleeving (shamoo)
Eh perhaps boring is what I should be asking about in that case. I do not need reinforced sleeves but just a larger diameter bore. The engine will be NA. How much can be bored on a stock B18A bottom end?
Old Jan 21, 2002 | 05:09 PM
shamoo's Avatar
My friend who is doing block and head work told me that going 10 over on the block will be just a little over 1.9L. You don't want to go nuts if you're running turbo (I am). I know for a fact, you can make it 2.0L easily.
My friend says he gets charged $100 once the block is out. The actual shop charges $165 for a walk in customer.
Old Jan 21, 2002 | 05:22 PM
teg92's Avatar
Well ideally I'd like to just bore it to run 84mm or 84.5mm pistons for a b20b/z block. The application will be NA for its whole life.
Old Jan 21, 2002 | 06:15 PM
non-VTEC's Avatar
84mm is out of the question on the B18 sleeves...........you can "probably" get away with 82mm but even that is pushing it............the maximium honda recommends is 81.5 (.020 over)
i guess if you dont plan to make huge gobs of power you can probably get away with custom 82mm pistions........
Old Jan 21, 2002 | 06:51 PM
The Punisher's Avatar
Default Re: Cost for sleeving (non-VTEC)
If you guys are interested in the Golden Eagle Sleeve me on my email: brandon.gilstrap@verizon.net I will give you the lowest price, only because I am not trying to make any money, just passing the savings, you know what I mean.
Old Jan 21, 2002 | 07:16 PM
HaUTSaauce's Avatar
New User
just leave the b20 block man thats my 2 cents
Old Jan 21, 2002 | 07:35 PM
IMPATIENT's Avatar
Default Re: Cost for sleeving (HaUTSaauce)
yea right brandon, what's up with loaning me $1000 buck s to get my pistons and rods, how about you find me a b18 b block and get it resleeved for me, i'll pay you back later..haahaha........i heard you guys got the pistons and rods today, when are the blocks gonna be ready so i can get chris's blown block and send it out........can't wait for the season to start to see your run...finally....
Old Jan 21, 2002 | 07:51 PM
bigTom's Avatar
.10 over will not produce 1.9l... 84mm (which is technically 1.20 over) will yield around 2.0l
iamthefollower
Feb 15, 2010 01:53 PM
nos4a2si
May 16, 2005 08:27 AM
Mr.Saturn
Jul 3, 2003 01:15 PM
USDMMARK
Feb 9, 2003 01:58 AM
