what oem intake arm b16a swap
Old Mar 1, 2005 | 06:33 PM
wrXtian's Avatar
Default what oem intake arm b16a swap
i was curious what kind of oem intake arm and air box you use for your b16a swap. i have a 91 oem civic si intake arm, but the arm looks really small compared to others.. which ones are you guys using? i want a oem intake arm and air box not a aftermarket one.
Old Mar 1, 2005 | 06:40 PM
crxnj's Avatar
Default Re: what oem intake arm b16a swap (D16A6_HF)
My friend has a 94+integra ls,rs,gs arm and a k&n drop in filter..Queit and makes power..
Old Mar 1, 2005 | 06:52 PM
wrXtian's Avatar
Default Re: what oem intake arm b16a swap (Mr.speaker)
does that intake pipe sit at a different angle? somewhere around where the battery tray is?
Old Mar 1, 2005 | 06:53 PM
kulangot's Avatar
i used the stock a6 on my ls...
Old Mar 1, 2005 | 06:55 PM
honda06si's Avatar
when my motor came in it had the oem intake arm on it...its probably 3 inches wide, or whatever...... if you want it i can sell it to ya....and yea just put a filter on it and it would sit right behind the passenger headlight
Old Mar 1, 2005 | 06:57 PM
honda06si's Avatar
Default Re: what oem intake arm b16a swap (honda90si)
well, i didnt read that you wanted a stock airbox.... i can check tomorow and see if the si air box and the sir arm fit well wit the battery
crxnj's Avatar
Looks like this,,Had to cut some off the intake box tube...
Old Mar 1, 2005 | 07:01 PM
wrXtian's Avatar
wow that's clean.. is that the civics intake box or the integras?
Old Mar 1, 2005 | 07:04 PM
honda06si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
wow
Old Mar 1, 2005 | 07:08 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16A6_HF &raquo;</TD></TR><TR><TD CLASS="quote">wow that's clean.. is that the civics intake box or the integras?</TD></TR></TABLE>
Its the stock civic box..And its not my car..I was just using the pic for an example..
Its Eggman's car..And **** does look clean
Todd00
17
Oct 22, 2015 03:26 PM
gosu08
Jan 28, 2007 03:55 PM
5-SpeedFreak
May 31, 2003 05:01 AM
azn_outlaw
Feb 26, 2002 09:31 AM
