PR3 Piston Questions
Old Mar 1, 2005 | 06:03 PM
Radyjr's Avatar
Default PR3 Piston Questions
i got a quick and dumb question. i have a stock B16A2 Block does anybody know if .20 oversized would fit it...
Old Mar 1, 2005 | 06:18 PM
SCIVIC94's Avatar
Default Re: PR3 Piston Questions (Radyjr)
you have to take the block to the machine shop and have them machine the cylinders 20 over.when you take the block,also take the pistons so they can double check everything.if you have the money have them balance and blueprint the entire bottom end.it is worth it.make sure it is a reputable shop.good luck
Old Mar 2, 2005 | 04:32 AM
Radyjr's Avatar
Default Re: PR3 Piston Questions (SCIVIC94)
how much to have it oversized
Old Mar 2, 2005 | 03:54 PM
Radyjr's Avatar
bump anybody know
Old Mar 2, 2005 | 08:00 PM
SCIVIC94's Avatar
depends on shop
Old Mar 5, 2005 | 07:07 PM
Radyjr's Avatar
what is the cheapest you have seen
Old Mar 5, 2005 | 07:18 PM
rob...'s Avatar
i just depends on the shop, and their skill and reputation. i go to this shop in cleveland that does mostly deisel service, but my buddy works there so i have had them bore a block for me. also you want them to use a torque plate when they bore it over. what this does is similate the cylinder head being bolted down and gives you the true bore shape. but i would expect for you to pay about $100-$150. i did mine on a sunnen ck-10 which is the sweetness. it acually hones the cylinder to the bore size you need rather than boring it out. you can gat a lot better finish and tolerences at .0001.
Old Mar 5, 2005 | 08:03 PM
CaptivaBlue's Avatar
Default Re: PR3 Piston Questions (baseballinmyass)
When you say 100-150 I assume you mean bring the block in separate of the car, right?
Old Mar 5, 2005 | 08:13 PM
rob...'s Avatar
Default Re: PR3 Piston Questions (CaptivaBlue)
but of course.
GReddy SI
Jun 8, 2012 09:17 AM
GReddy SI
25
Jun 5, 2012 05:25 AM
jiggacivic
Aug 11, 2011 09:35 PM
b18bEKcoupe
Jul 4, 2007 07:11 AM
svw
Apr 3, 2004 10:17 PM
