B16a2 has scored cylinder wall - Can block be saved?
well i opened up the block and i see this
can it be saved? its doesnt feel that bad. its at 81mm bore , with 81mm pistons.
if i take it to machine shop could i tell them to bore it to 81.5?
could that work?
could that work?
Re: Can it be saved?
It should work as long as that gouge is less than .25 mm deep. I think up to 81.5 mm bore on a stock block is ok. Honda says max is 81.07, but you hear of lots of people running that and doing good
go 81.25
make sure the inperfection doesnt catch your fingernail when dragged over it.
if it does maybe go towards 81.50
Are you aware of what caused it?
Faulty piston ring,
Broken ring land??????
Don't know you havnt explained your setup and the circumstances of the failure,
Makes it hard to paint a picture!
yeah it has a little chip where the oil jet hit,
i just search wiseco pistons hitting oil jets
looks like it happened to alot of people ,
they said bent them or cover the hole up
