what is a missing link........where does it go
Old Mar 1, 2005 | 12:39 PM
1991b16turbo's Avatar
Default what is a missing link........where does it go
I have a 1991 civic 4dr dx w/ swap to a b16a1 turbo. Engine light comes on under acceleration, vtec dont work. Was told tht I need a missing link, what is it and where does it go??And where can I get one if that is my problem?
Modified by 1991b16turbo at 3:34 PM 3/1/2005
Old Mar 1, 2005 | 02:39 PM
drdisco69's Avatar
Default Re: what is a missing link........where does it go (1991b16turbo)
A missing link is a check valve that prevents the MAP sensor from recieving positive pressure from the manifold. When it gets boost, the ecu sets a check engine light, because it's not expecting that. It goes on the vacuum line between the motor and the MAP sensor.
I have no clue where to get one for a good price, I can't afford boost.
Old Mar 1, 2005 | 03:28 PM
dustin's Avatar
The aluminum thing under the map sensor is a missing link. It's a check valve inside a block of aluminum.
Old Mar 2, 2005 | 06:23 PM
JdmEKCivic's Avatar
Default Re: what is a missing link........where does it go (dustin)
So pretty much just unscrew your map sensor (on top of your tb) and place the missing link there, then put the map on top of the missing link and tighten down.
Old Mar 2, 2005 | 06:27 PM
Default Re: what is a missing link........where does it go (JdmEKCivic)
thanks......now i know where it is.........but where can i get 1
Old Mar 2, 2005 | 08:26 PM
PrettyLude's Avatar
ebay, synaspeengineering.com
Old Mar 2, 2005 | 10:20 PM
KFBhonda's Avatar
Default Re: (PrettyLude)
Missing Link
shipped to you -> $36
Old Mar 2, 2005 | 10:37 PM
dustin's Avatar
Default Re: (KFBhonda)
Is that high quality bolt on the left included, or is that extra? hehe
Old Mar 3, 2005 | 07:25 AM
senpai's Avatar
Default Re: (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Is that high quality bolt on the left included, or is that extra? hehe</TD></TR></TABLE>
haha, it's a jdm stripped philips screw
Old Mar 3, 2005 | 06:16 PM
hybridpatient95's Avatar
you can make one using check valves from your local pet shop.. lol
Old Mar 3, 2005 | 09:57 PM
KFBhonda's Avatar
yeh smart asses, that bolt is included.
that's how i got it, used off egay.
it's a stripped screw and i took a picture of it.
truth in phukkin advertising for once.
Old Mar 3, 2005 | 10:12 PM
dustin's Avatar
Hehe it's just a remarkably good picture
Old Mar 3, 2005 | 10:40 PM
KFBhonda's Avatar
ok, dustin, thanks.
i do like my 2.0 Mpixel Panasonic digicam.
it has a very nice lens.
wow this post is way off topic. oh well.
Old Mar 7, 2005 | 04:27 PM
my map sensor is not on the t-body................where is it........obd0 comp
Old Mar 7, 2005 | 04:42 PM
Jim Truett's Avatar
Do you have any fuel management for the turbo?
Ditch the check valves and have your ECU read boost: http://www.turboedit.org/index.php
http://www.pgmfi.org
Old Mar 7, 2005 | 04:54 PM
stock comp....450cc injectors, i think they are too big.........gettin a FMU....no fuel mngment controls
Old Mar 7, 2005 | 08:28 PM
mmuller's Avatar
Mad Scientist
Fmu and check valves... i thought nobody used those anymore..for the price of that you can run a chipped for boost ecu and jim sayd.
fmu..just dont do it..
nicktagz
Sep 8, 2006 11:01 AM
Civiclx
12
Jul 26, 2004 02:06 PM
BoOsTiN Dc2
Sep 29, 2003 07:33 AM
SickRevHrdTeg
Aug 14, 2002 06:11 PM
ludelvr
May 31, 2002 06:20 PM
