compression and leakdown test results
Old Feb 28, 2005 | 05:24 PM
Kyles ej1's Avatar
Default compression and leakdown test results
i just did a compression and leakdown cuz i think my hg is going, here are the results
compression
cyl 1-200
cyl 2-200
cyl 3-195
cyl 4-205
leakdown
cyl 1-20%
cyl 2-20%
cyl 3-60%
cyl 4-10%
i think i know where the problem is so i might be taking off my head this week.
Old Feb 28, 2005 | 05:28 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: compression and leakdown test results (93blkej1)
real bad. What engine? If it's a pre 96 D series non vtec, there is a Service Bulletin on the head gaskets....they always fail
Old Feb 28, 2005 | 05:29 PM
Kyles ej1's Avatar
Default Re: compression and leakdown test results (Evs-One)
93 d16z6
Old Feb 28, 2005 | 05:30 PM
Evs-One's Avatar
Solbros Owns Me
you set each cylinder to top dead center for the leak down, corect??? Did you hea air leaking through intake, exhaust, or other cylinders??
Old Feb 28, 2005 | 06:35 PM
Kyles ej1's Avatar
yes set to tdc, i dont know too much bout leakdown tests so its hard to answer your question but i found a hole in the side of my intake
lsdc4
Mar 25, 2009 10:42 PM
Silvertc
Mar 1, 2009 06:58 AM
dreamreaperx
Dec 20, 2006 02:01 PM
highrolla
Jan 21, 2004 07:31 PM
