D16z6 head with a temp d15XX swap leaking oil into radiator... HELP
I have never heard of oil getting INTO the radiator, it's always been the reverse, i've drained the oil, and there's no water in the block, does anybody have an idea what's going on?
Re: D16z6 head with a temp d15XX swap leaking oil into radiator... HELP (DemostheneZ)
when you have a bad or blown headgasket, oil gets into the coolant and coolant gets ito the oil. its not always necessarly both it could be on or the other
Re: D16z6 head with a temp d15XX swap leaking oil into radiator... HELP (hondaguyexsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyexsi »</TD></TR><TR><TD CLASS="quote">when you have a bad or blown headgasket, oil gets into the coolant and coolant gets ito the oil. its not always necessarly both it could be on or the other</TD></TR></TABLE>
yup a bad headgasket would be about the only way to get oil into your coolant and vice-versa. unless there is an oil cooler or something i dont know about, but im pretty sure there isnt on civics
92jdmhatch
10
12-28-2004 07:53 PM
