A/C compressor problem/question
Old Feb 28, 2005 | 02:37 PM
noworldorder's Avatar
Default A/C compressor problem/question
Hello,
I have a 2000 civic and the a/c compressor has been making a wierd squeching noise. I know its the a/c compressor because I took off the a/c belt and the noise was gone. I was wondering if I have to change the whole a/c compressor unit or can the compressor be taken apart and fixed? I don't know what's wrong with it so I could really use some help here. The a/c work fine, and the noise didn't change when I turned the a/c on. The pully turns freely and I didn't notice any play. I did do a search but didn't find a answer. Thanks.
Old Feb 28, 2005 | 02:50 PM
RedlinedVTEC's Avatar
Default Re: A/C compressor problem/question (noworldorder)
Probably best just replacing the compressor, shouldn't be too expensive to get one from schuck's or car quest or Oem from hondaautomotiveparts.com or slhondaparts.com.
Old Feb 28, 2005 | 03:22 PM
PrettyLude's Avatar
you can just change the clutch on the compressor you don't have to buy a new compressor
Old Mar 1, 2005 | 06:30 AM
JimBlake's Avatar
Default Re: (PrettyLude)
Does that AC belt have an idler pulley like on B-engines? First check to see whether it's that idler making the noise...
Old Mar 1, 2005 | 01:42 PM
Default Re: (JimBlake)
Yes it does. Today it finally froze up, and I had to just cut the belt off. Would a bad clutch freeze up or is it something internal (bearing, piston etc..)?
Old Mar 1, 2005 | 03:45 PM
Chiovnidca's Avatar
Default Re: (noworldorder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noworldorder &raquo;</TD></TR><TR><TD CLASS="quote">Yes it does. Today it finally froze up, and I had to just cut the belt off. Would a bad clutch freeze up or is it something internal (bearing, piston etc..)?</TD></TR></TABLE>
Did the compressor pulley seize up or the idler pulley?
Old Mar 1, 2005 | 06:22 PM
Default Re: (Chiovnidca)
I'm not sure, I'll have to let you know. I would of checked it today but we're in the middle of a snow strom...
hillbillycivic
10
Mar 3, 2013 09:02 AM
the soL that could
Aug 15, 2011 02:54 PM
092eg6
Aug 23, 2010 08:30 AM
Azn Kenny
Oct 8, 2007 01:55 PM
EKidd
Jun 16, 2007 06:02 PM
