Map sensor wiring order on the harness?
Old Feb 28, 2005 | 01:59 PM
HaveNoLife's Avatar
Default Map sensor wiring order on the harness?
Hello,
I have a 2000 Prelude auto and the original map sensor plug on the harness was damaged. I was able to locate another plug but from a different Honda, not sure exactly what it came off of.
Question is, which wires go where on the plug? I know the red/green is map, red/yellow is power, and green/white is ground, but i was in a hurry and forgot to note thier locations on the plug.
I attached a drawing to illustrate my question. Thanks for any help.
Old Feb 28, 2005 | 02:03 PM
98TypeSH's Avatar
Default Re: Map sensor wiring order on the harness? (HaveNoLife)
Looking at the plug with the snap part of the connector on the TOP from Left to Right
yellow/red, green/white, red/green just reverse of how you have it in the picture.
Modified by 98TypeSH at 3:22 PM 2/28/2005
Old Feb 28, 2005 | 02:16 PM
HaveNoLife's Avatar
Default Re: Map sensor wiring order on the harness? (98TypeSH)
Cool, thanks!
Old Feb 28, 2005 | 02:25 PM
98TypeSH's Avatar
If this is the top of the connector then like this.
Old Feb 28, 2005 | 02:30 PM
HaveNoLife's Avatar
Thanks again!
Old Feb 28, 2005 | 02:39 PM
HaveNoLife's Avatar
Another question, if the red/yellow and the red/green were crossed, would it be possible to fry the ECU?
Old Feb 28, 2005 | 02:42 PM
98TypeSH's Avatar
i dont think it would fry the ecu but rather fry the map sensor. Try to uncross the wires and get everything hooked up correctly and keep your fingers crossed
Old Feb 28, 2005 | 02:45 PM
HaveNoLife's Avatar
Well, wired the map correctly, and reset the ECU but it will not start. May have to try a different map. I have a 95 GSR map. Are they pretty much the same or do I need to stick with the factory map? Thanks.
Old Feb 28, 2005 | 05:22 PM
98TypeSH's Avatar
pretty sure most honda maps are the same.
Make sure you got the firing order correct on the plug wires.
russd210
May 22, 2011 11:35 AM
tacosandbeans
Sep 20, 2010 10:44 AM
00si2
Apr 12, 2009 04:52 PM
JDMlyfestyle
Oct 17, 2004 05:27 PM
nolimits
Sep 16, 2003 08:47 PM
