help with slave cylinder please!
Old Feb 26, 2005 | 10:41 AM
gtowni3's Avatar
Default help with slave cylinder please!
ok i put on the new slave and im bleeding it and everything is good , the clutch is getting stiffer etc, im doing this for about 15 minutes....and then when i think its done i keep pumping it just to make sure its stiff and the boot on the slave fills up with fluid and looks like its gonna blow up the more i pump it, so i have NO choice but to bleed again and again and it wont stop looking like its gonna explode....is the o ring gone bad in the new slave already?// please help thanks
Old Feb 26, 2005 | 10:45 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: help with slave cylinder please! (gtowni3)
did you go with e new one or a re-man?
sounds like you got a bad one.
Old Feb 26, 2005 | 10:46 AM
gtowni3's Avatar
Default Re: help with slave cylinder please! (boostedcivicsir)
new one and now i have to go pick one up 2moro morning
Old Feb 26, 2005 | 10:47 AM
gtowni3's Avatar
what could have gone wrong, did i pump too many times?
the boot on the slave after about 5 pumps it looks like its gonna burst ,btw
Old Feb 26, 2005 | 10:49 AM
Mr. Badwrench
i have never seen it happen but possible the seal could have been installed backwards.
Old Feb 26, 2005 | 11:12 AM
gtowni3's Avatar
more help plzz
Old Feb 26, 2005 | 06:19 PM
gtowni3's Avatar
wow im a ******* idiot, nevermind
Old Mar 15, 2005 | 05:43 PM
bboylito's Avatar
well what was it???
Old Mar 16, 2005 | 04:08 AM
EE_Chris's Avatar
Default Re: help with slave cylinder please! (bboylito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboylito &raquo;</TD></TR><TR><TD CLASS="quote">well what was it???</TD></TR></TABLE>
Old Mar 16, 2005 | 08:16 AM
ironlung78's Avatar
Default Re: help with slave cylinder please! (EE_Chris)
you don't have to pump the clutch pedal to bleed it..
you just open the bleeder screw on the slave cylinder and let gravity do its thing.
Old Mar 16, 2005 | 08:18 AM
snatch's Avatar
Default Re: help with slave cylinder please! (sidesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sidesi &raquo;</TD></TR><TR><TD CLASS="quote">you don't have to pump the clutch pedal to bleed it..
Really? I understand it will drip out and ****, but I think pumping the clutch helps.
edit: To original poster....what was the problem?
Old Mar 16, 2005 | 08:22 AM
eRaceParts_com's Avatar
The unit was probably just a defect. You should be able to pump it thousands of times. Just imagine how many times you pump it over 200,000 miles of city driving. A good one should hold up.
Old Mar 17, 2005 | 12:11 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtowni3 &raquo;</TD></TR><TR><TD CLASS="quote">i keep pumping it just to make sure its stiff and the boot on the slave fills up with fluid and looks like its gonna blow up the more i pump it.....</TD></TR></TABLE>
what exactly are you talking about here?
Ashwell33
Transmission & Drivetrain
Feb 15, 2019 11:54 AM
kulrevon
Oct 24, 2006 04:22 AM
yOnKiNaToR
Oct 23, 2005 05:44 PM
90babyblue
Apr 30, 2004 03:43 AM
iwhichisme
Mar 16, 2004 05:48 PM
