A/C gets warm when rpm's are low. what's the problem. the compressor?
Old Feb 25, 2005 | 07:00 PM
booja's Avatar
Default A/C gets warm when rpm's are low. what's the problem. the compressor?
my a/c works when i'm driving or when theres a load on the motor.
once i put it in neutral it gets warm. its still blowing some cool air out but but hardly enough to keep me cool.
if im in neutral and i rev to 3k itll blow a lil cooler then it would at idle but not as cool if i were actually driving.
whats wrong with it? is it my a/c compressor itself. or the other parts like the clutch or the expansion valve or what?
i just wanna know what it is before i go off buying stuff i dont need.
i need to get this fixed quick. its already getting warm in houston.
Old Feb 25, 2005 | 07:39 PM
drdisco69's Avatar
Default Re: A/C gets warm when rpm's are low. what's the problem. the compressor? (booja)
You may not have enough refrigerant in the system. Get it recharged and see if that helps. Have them put in the dye so if it gets warm again you can check for leaks.
Old Feb 25, 2005 | 09:44 PM
booja's Avatar
yeah ive refilled it still the same
Old Feb 26, 2005 | 12:26 AM
eda6's Avatar
Is the belt loose? What were your final pressures after you topped it off? Maybe non-condensables in the system.
If your compressor was bad it wouldn't cool at all. Did you notice higher than normal suction pressure and lower than normal discharge pressure? If you did the valves in the compressor are going out.
Old Feb 26, 2005 | 04:38 PM
booja's Avatar
i havent checked the discharge or suction pressure, but i checked the after i put 2 cans in. and it was normal.
i figured if the compressor was bad it should cool at all. i believe my belts are tight. not squeaking or anything
Old Feb 26, 2005 | 08:48 PM
Mike K's Avatar
Default Re: (booja)
you realize that too much refrigerant can make temps warmer than they should be, right?
award78
Honda CR-V & Element
11
Sep 12, 2022 02:24 PM
blackcrx16
Jul 9, 2009 01:48 PM
95teg_ls
Jul 25, 2008 10:29 PM
excivicboy96
May 11, 2007 03:57 PM
fongph
May 26, 2006 12:39 PM
