Weid AC problem
Old Jul 23, 2008 | 07:22 AM
95teg_ls's Avatar
Default Weid AC problem
So i just put in a new compressor and new freon and everything, and it works like fine at idle (arond 50 or 55 degrees). once i drive it or just let it sit at 1500 rpms it cycles fequently and is no longer cold air (about 65 degrees). however when i have a gauge set on it, and its hooked up to the high side then it will run just fine. does this sound anything like a clogged evaporator or a bad expansion valve? has anyone else had this problem?
Old Jul 23, 2008 | 12:10 PM
vtecb18c's Avatar
Default Re: Weid AC problem (95teg_ls)
well considering that the expansion valve regulates the rate of flow of refrigerant into the evaporator i would imagine that would be your problem...i would think if the ecaporator was glogged than you wouldnt have colr air at all idle or not
Old Jul 23, 2008 | 05:29 PM
95teg_ls's Avatar
Default Re: Weid AC problem (vtecb18c)
alright... thats what i figured, i guess im gonna have to drain the freon for the second time and fill it, hopefully this will fix it.
Old Jul 23, 2008 | 10:37 PM
r1lsr's Avatar
you probably put too much refridgerant in it because at high compressor speeds the freon does not have enough time to change phase from saturated liquid to gas. Thats why it worked at low speeds.
Old Jul 25, 2008 | 10:29 PM
95teg_ls's Avatar
Default Re: Weid AC problem (r1lsr)
i dont think i did, because i put too much in to begin with then i took enough out. it was at about 38 or so, so it should be good. im gonna try this expansion valve and then only put in 24 oz of freon.
award78
Honda CR-V & Element
11
Sep 12, 2022 02:24 PM
PolkaSauce
16
Oct 31, 2019 09:30 AM
NAxSOLDIER
Jun 10, 2011 08:06 PM
B18C-YA!
Aug 28, 2006 01:34 PM
VTECRaZeR
Sep 26, 2003 04:35 AM
