No spark from distributor
Recently, after checking the compression in my 93 del Sol vtec, my distributor stopped giving a spark. The car cranks, but doesnt start. I've checked every plug I can, checked the fuses, and I tried unhooking the negative battery cable for a few minutes. Anyone run into a similar problem like this before?
-Joel
-Joel
Isnt the coils part of the distributor. Yes, I'm not getting a spark at the coils. I'm not familiar with the ignitor. I've got my manual in front of me, and I dont see it in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joel2204 »</TD></TR><TR><TD CLASS="quote">Isnt the coils part of the distributor. Yes, I'm not getting a spark at the coils. I'm not familiar with the ignitor. I've got my manual in front of me, and I dont see it in there.
it's also known from the factory as the ICM= ignition control module.
</TD></TR></TABLE>it's also known from the factory as the ICM= ignition control module.
I unplugged the wires from the plugs and not anywhere else. Could I have shorted something out? I had also washed the car. Maybe some water got on a connection when I opened the hood.
you need to replace the coil. when you crank it over without the plugs hooked up to the wires it will often fry the coil. 99% chance that's your problem. make sure you replace it with a factory one. or a used honda coil the ones from autozone and advance suck. hope that helps. next time unhook the 2 pin connector from your dizzy before runnign the compression check.
seth
seth
nonvtec92
Aug 26, 2010 01:46 PM
nwdave
Jun 30, 2004 03:10 PM
