De-socketing an ECU
De-socketing an ECU
How do you remove or disable a socketed ecu so it runs like stock again? Can you just un-solder it and it will run stock again?
Re: De-socketing an ECU (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote">cut the j1 jumper then you back to stock. </TD></TR></TABLE>
Sick okay where is that exactly on this picture??
Re: De-socketing an ECU (95excoupe)
Don't forget to ground yourself when holding the ecu and store it on a static proof rubber mat. (Friend didn't do this and totally screwed his ecu). Good to here you found it. Pretty obviouse when it is open . Good luck.
