91 civic hatchback turn signal flasher
Old Feb 25, 2005 | 12:21 PM
jaw174's Avatar
Default 91 civic hatchback turn signal flasher
Hey there.
i jsut got a 91 civic hatchback. the left hand front turn signal got damaged and the bulb broke. after replacing it, it decided to go into "hyperspeed" mode, flashing rather fast.... do i need a new flasher unit, oris ther somehting i can look for. the hazard lights work at normal speed.
Old Feb 25, 2005 | 07:28 PM
AintGotNoSol's Avatar
Default Re: 91 civic hatchback turn signal flasher (jaw174)
only thing i know of that causes the bulb to flash quickly is when one of the bulbs for that side is burned out.
check the rear bulbs for that side as well, because if one of those is out, it will flash quickly.
also you should keep in mind that there are 2 bulbs in the corner light up front, the parking light bulb, and then the turn signal bulb. just make sure you got bulbs in both of them. and make sure they are correct. AND there is another turn signal bulb in the lower front part of the bumper.
other than the bulbs though , i dunno. i guess make sure they are all the correct bulbs, and they all work. if thats not it. ask someone who knows waht they are talking about a little more than i do!
Old Feb 25, 2005 | 07:50 PM
delslo93's Avatar
try posting in the right forum. CRX / EF Civic forum people could help you out better then us. But its most likely a burnt out bulb that is causing it. Make sure that the new bulb you put in is in correctly.
Old Feb 26, 2005 | 03:20 PM
jaw174's Avatar
ahh...there is no bulb in the bumper...the entire assembly is gone..hehe that is the culprit i assume.
..ahh i see, civics pre 92.. got ya
Timothy Yhtomit
10
Nov 17, 2021 06:28 AM
civic4life8045
14
Dec 25, 2012 03:06 PM
philibuster
Aug 30, 2004 10:28 PM
1Tym
Jun 19, 2003 06:12 PM
B16ED4G
Feb 27, 2002 07:43 AM
