bumper turn light question
Old Aug 30, 2004 | 07:42 PM
philibuster's Avatar
Default bumper turn light question
My right turn signal has gone hyper blinker! I took out the bulb and both bulbs seem to work fine. If I mess with the bulb a little bit, it'll blink fine then go back to hyper blinker. Could it be the wiring and if so, what do AH DOOOO?!
Thanks!
Old Aug 30, 2004 | 08:23 PM
GreenStreetTurbo's Avatar
Default Re: bumper turn light question (silverblurr)
check the wires around the conector they might be bad.... but first get a new bulb i might be on its way out.....also check the rear bulbs they might be out causing them all to blink fast
Old Aug 30, 2004 | 08:54 PM
The-LS's Avatar
you check the blinker/signal bulb in back? wait... that doesn't make sense if you messed with it and it works... clean the contacts? Change the bulbs just to be sure?
Old Aug 30, 2004 | 10:28 PM
LEGEND_101's Avatar
Default Re: bumper turn light question (Black-LS)
If it works and then didn't work then it could be one of your filaments in yur duel filament bulb could be out. You can see it as well. All you have to do is turn on your blinker, and then shake the bulb. You could see the filaments are broken or not. It could also be the turn signals in the back on the same side too. If it's not one, then it's the other.
mookie
Honda Motorcycles
Sep 7, 2006 03:17 PM
jaw174
Feb 26, 2005 03:20 PM
bogus_ek
Feb 9, 2005 06:47 AM
jdm_junkie
Aug 12, 2004 06:09 PM
