does n e one know? boost
Hey guys, I'm having trouble finding someone to help me with my question. I need to know where the wastegate hooks up(2 lines), and also the Blow Off Valve(1 line). Please help.
yeah you can get a few T's and go from there, just dont use the fuel pressure regulator line. i ended up getting a golden eagle vacuum manifold (40$ or so) and sourced the vac. from the brake booster. wastegate is pretty important so i'd make sure you havea good vac. source and make sure the hose is ziptied or sequred tightly!
