Garrett t3 water fittings size..
Old Feb 25, 2005 | 05:12 AM
GaRn's Avatar
Default Garrett t3 water fittings size..
What in the world is the size/thread of the water fittings on a garrett t3 60 trim?
The turbo I have is a 60 trim T3 from a 300z, .52/.63 AR, and no fittings from lowes will fit it..
Old Feb 25, 2005 | 05:29 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Garrett t3 water fittings size.. (GaRn)
then you didnt look hard enough
the threads are 1/8th npt,i got my fittings from lowes
Old Feb 25, 2005 | 07:02 AM
beepy's Avatar
Lowe's only carries 35° nipple and NPT. No automotive fittings. Should be a banjo bolt fitting.
Old Feb 25, 2005 | 10:06 AM
GaRn's Avatar
Default Re: Garrett t3 water fittings size.. (beepy)
No, I want it to be a straight fitting to hose... I looked hard, trust me, I brought in the old fitting and tested it out in the test fit thingies.. they didnt have the size so i had to use some adapter BS and it isnt fitting correctly.. I think it is 3/8 NPT for the water fittings.. I will have to look at Home Depot
StolenTeg
Sep 29, 2007 09:58 AM
inspyral
Sep 8, 2004 08:59 PM
inspyral
Sep 8, 2004 08:17 PM
Scott - 93HB Si
Apr 29, 2003 03:00 PM
