'void if removed' plug on my b16 block.. wtf?
Old Feb 24, 2005 | 06:19 PM
thatbluecrx's Avatar
Default 'void if removed' plug on my b16 block.. wtf?
im assuming this block was remanned?
Old Feb 24, 2005 | 07:20 PM
Wes V's Avatar
Default Re: 'void if removed' plug on my b16 block.. wtf? (thatbluecrx)
Is it a plug or something that is held on with a glue that will let go if the engine hits a certain temperature?
Old Feb 24, 2005 | 07:46 PM
Default Re: 'void if removed' plug on my b16 block.. wtf? (Wes V)
maybe? like a freeze out plug?
Old Feb 24, 2005 | 07:53 PM
civicross's Avatar
Looks like something from a salvage yard. I've seen those at one here in town. If it overheats it changes color or falls off or something like that.
Old Feb 24, 2005 | 07:57 PM
Tony the Tiger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatbluecrx &raquo;</TD></TR><TR><TD CLASS="quote">im assuming this block was remanned?
You mean the cylinder head, right? That's not the block in the above picture
Old Feb 24, 2005 | 08:26 PM
Dan GSR's Avatar
lol, i know where u got ur engine
Old Feb 24, 2005 | 09:10 PM
mmuller's Avatar
Mad Scientist
Default Re: 'void if removed' plug on my b16 block.. wtf? (Dan GSR)
did you buy that engine at IAS?
Old Feb 24, 2005 | 09:17 PM
FastEK9's Avatar
Default Re: 'void if removed' plug on my b16 block.. wtf? (mmuller)
That is to retain your warrenty, if you over heat that motor that tag will fall off and void your warrenty. it is a way for the "seller" to determain how your engine is now needing the warrenty.
Runnerdown's Avatar
Tons of machine shops and junkyards/importers put those on.
Old Feb 25, 2005 | 05:59 AM
civicminded92's Avatar
Default Re: (Runnerdown)
That's really slick - I've never seen that before. That's one way to keep tabs on your customer. Unless your customer takes it off and uses the same glue/adhesive to put it back on after it overheats......
Old Feb 25, 2005 | 06:07 AM
Default Re: (civicminded92)
doh im an idiot yea thats my head hahaha<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">
You mean the cylinder head, right? That's not the block in the above picture </TD></TR></TABLE>
The motor was bought From MOTORWORKS on Long Island, they said 30-40k on this motor I dont even think it had a warrenty.... either way its got about 60k on it now
the motor is loud, noisey as **** but doesnt blow any smoke or anything(or are all 1st gens in rexes sound like beasts? or is that the hasport mounts?)
CRX91SE
Aug 31, 2010 11:56 PM
spooned out
Aug 28, 2006 07:53 PM
xteg95
Apr 17, 2003 05:24 PM
Hoagieryder
Nov 20, 2001 11:27 AM
